It is currently Tue Oct 27, 2026 4:42 pm
PostPosted: Tue Jul 23, 2013 1:43 am
What I mean by this is that I record some movements and take it into the studio program. I try to use "track forward" and it begins to render but the model in the studio begins flipping out. One time the thing was curled into a ball at the edge of a stage and the other time it had one arm in the T pose and the other moving around inside it's own body.
Maybe I'm just being dense and I missed a crucial part. There is something I'm curious to if it would affect this is the fact that I'm not actually using my main computer, I once installed the trial then had to leave it due to a holiday and by the time I remembered about it, the thing had expired. So I'm using my laptop instead which may not meet processing specifications. Could that cause it to screw up?
PostPosted: Tue Jul 23, 2013 1:33 pm
Tracking errors do occur sometimes, not depending on hardware. This is quite normal. There are a number of ways to fix them. One that is used more often is:
  • find a frame after error where the actor's pose is good visible
  • manually adjust the model to roughly fit the actor (you can copy the pose from one of the previous good frames to do less work)
  • hit "Refit Pose"
  • if there is an error again, adjust the pose more accurate or choose another frame and repeat the above steps
  • once you have a correct pose, hit "Track Backward" to correct the erroneous frames
Once you get used to it, it's a really simple procedure.
Users browsing this forum: Google [Bot] and 70 guests
