It is currently Wed Oct 28, 2026 10:42 pm
PostPosted: Fri Aug 09, 2013 10:25 am
I deinstalled the previous version and then installed the all new 2.4.
When the install routine starts iPi Mocap, the following error appears. And from now on every time I try to start the programm.
------------------------------ ERROR -----------------------------
iPi Mocap Studio version 2.4.0.154 [<unknown>]
.NET: 2.0.50727.5472
OS: Microsoft Windows NT 6.1.7601 Service Pack 1
System.NotImplementedException: Die Methode oder der Vorgang sind nicht implementiert.
bei #=qVyjnvVH_cZqZpIv6zmjZLExk3YP6OaPlIJyTdUKgnHof2sMVFgoaUcLLqx9xRel9.#=qTSKoAIe1c64xzcGdlESG5g==(Int32 #=q_2AhMqeTg6QpxbzD0ULUVxxfkY1Z92UeDVJ_h9UVbZ8=)
bei #=q307MfWrWJR0xjHgjK63$CsQfZIXsCcE7vgZaGdkIPmvrKnFMvkkscbxvzkObEQm8..ctor(#=qlfiSARJxOChlv_orYuq$rhdumSLdNlFAV9dVvVRrcFTkkyH5f6Svy5p_zCYyGW9n #=q8YGi3Fr5Q0UGqwZU7XcGvg==, ContentManager #=qPklqqRhYBNqQxEHJEakq3g==, Int32 #=q7Az_j3_wVUdmgKdFCSV2DA==, Boolean #=qYfde6EJRENyrky0KozJ9wjxFBhvB4nvGaBZ_lpaUBzs=, Int32 #=qesmuzpR5$rgy48Ab41KDAz4iN0gd_ZFFKoRnZjiHb58=, String[] #=qzc5Hv5aluChL13jylAmDvw==)
bei #=qVyjnvVH_cZqZpIv6zmjZLExk3YP6OaPlIJyTdUKgnHof2sMVFgoaUcLLqx9xRel9..ctor(#=qlfiSARJxOChlv_orYuq$rhdumSLdNlFAV9dVvVRrcFTkkyH5f6Svy5p_zCYyGW9n #=qDcpcm0EizHJOqWq7HKI$WA==, ContentManager #=qcrT7ycP9kHjzBEMWq_7QmA==, Int32 #=qaAY99O9ovbpJyZuTu6eU3g==, Boolean #=q_fVoIFDqpa7W9TyYnXkJnh8krjmtSXzvjt5btDN5cw0=, Int32 #=qtsEMMu0UwrXgaz778IS9z7Hc17YPd8RHCpHmlLGWiO4=, String[] #=qZHI$QwUTpVH6$O92k8Q42A==)
bei #=qyyNUcYHw2gxzDNIJlnPs$Q62ntqanw98xU6KrU2lcI2DFvAqQWYwguVEEgWs951_PpPhbGpiLA5DGWHkqMpWMQ==..ctor(#=qlfiSARJxOChlv_orYuq$rhdumSLdNlFAV9dVvVRrcFTkkyH5f6Svy5p_zCYyGW9n #=qzsRgNXJloBHg1Yd_1zGCSg==, ContentManager #=q$ApGVRH5Zs5SH_PFfHkZ$A==, Int32 #=qg4ZRwNox3ss4xppWsNmwtg==, String[] #=qIMTRh$GArnd8JuKG6_ylfg==, Int32 #=qg319mTr4iAMmZ$JeKcpwHFt2hD7QQA$aY3dpatwzXSk=)
bei #=q_d_wxj6hvYFj05hPM_B$kPo2vCtzN3Rhe9EUk3HBc2CUISdaSiSHrR180tjcTr5TVt8zzhBG00Z8J4sFe1wSnQ==..ctor(#=qlfiSARJxOChlv_orYuq$rhdumSLdNlFAV9dVvVRrcFTkkyH5f6Svy5p_zCYyGW9n #=qTdbdUwNJUUnvNl8ScTskBQ==, ContentManager[] #=qh5L99obMDttMr5tcbJaKBrUZVfB$xcVyG18D5LIQpDc=, Int32 #=qN6XHo8u5B3s0FTJVzDzWBA==, String[] #=quPiD0qWWN56gjTMzM4xrQw==, Int32 #=qlaCBVstiNlX$0wLKeZgXfD0avzXeaVtbWyVSL9OYsdw=)
bei #=qiO3pD8H9gotXHVjEX3BbcEzde5VMaQhiILOF7JpD_g7wmn1XnZ7R8F3k$afxFgcg..ctor(#=qlJBBhxWe5JeiKBQDnjU9PHLPELehv9nWb772gxrMu9okifwjzeRBootQVWLk8TAS #=q_eBhRrcqL1HNQAnrwl14Kg==, Int32 #=q3MHXWHq7FHUc86HinPgyIA==, String[] #=qLILQ0zNQfC6dSOksL8jFQg==)
bei #=qHjZHMZRN0bt82YUTEN2chGgMs55g2nlwGpckVdbWBCGGXGWcB27eQumEUW1uPh8GYbwKNMgHheAs_Sb6rAc4xQ==..ctor(#=qlJBBhxWe5JeiKBQDnjU9PHLPELehv9nWb772gxrMu9okifwjzeRBootQVWLk8TAS #=qALceN0UqWBM$RCpHQX8h_w==, Int32 #=qAg36VVQzxWkrpkfzD$WGtQ==, Int32 #=qUcmelfpgNPjPEHPYSYrVOQ==)
bei #=qlJBBhxWe5JeiKBQDnjU9PHLPELehv9nWb772gxrMu9okifwjzeRBootQVWLk8TAS.#=qwOAH9SsM9pk_goDep1LXb7GbdGb1ujc7eF2rSw9EQAA=()
bei #=qlJBBhxWe5JeiKBQDnjU9PHLPELehv9nWb772gxrMu9okifwjzeRBootQVWLk8TAS.#=qJeOQeSNIX8HAc2jlZFLXbg==()
bei -.dje_qKJ7RL7L59Q3W7E39DMDAVSLKKM2VMDG4FWCYPV7CDHTHTZEQGCJVL5DL9VXYMM4QMN6YQYTXHBA8E_ejd.#=qA8JaYuTvGdBj43FrirpbQWvqNBFa7S89G1$f0iJZlKU=()
bei -.dje_qNPX5BCSF7JNWBBB5TDNVFV2JR9Z3DQS5EQP6G4MPTKBS9TTGRQ6A_ejd.#=q2wTCOrEnBYduTDTAPqxK4MizbAC7I_RyLgjQ_2vvBiw=(Object #=qnvD7aW3BWwtik2uv2NSnDQ==, RoutedEventArgs #=qPPu2SXlcfdLZiEJy6OXgDw==)
bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
bei System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
bei System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
bei System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
bei MS.Internal.LoadedOrUnloadedOperation.DoWork()
bei System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
bei System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
bei System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
bei System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
bei System.Windows.Media.MediaContext.Resize(ICompositionTarget resizedCompositionTarget)
bei System.Windows.Interop.HwndTarget.OnResize()
bei System.Windows.Interop.HwndTarget.HandleMessage(Int32 msg, IntPtr wparam, IntPtr lparam)
bei System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
bei MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
bei MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
bei System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
bei System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
PostPosted: Fri Aug 09, 2013 1:20 pm
There was no need to deinstall previous version, it could be updated normally.
Anyway, deinstallation barely could affect this issue. Most probably, it is video card/driver specific problem.
What is your video card(s) model?
Do you have the latest drivers for it?
PostPosted: Fri Aug 09, 2013 1:22 pm
I did some further tests:
My configuration has 2 GTX 580 graphic cards. And I have 3 Monitors. 21" -- 30" -- 21". The 30" monitor is plugged in the main graphics board, the two 21" are plugged in the other graphics board.
When I disable the two 21" monitors, the program is starting well. Also when I am connecting one monitor to the second graphics board.
The error arrives when I enable the third monitor. :-(
Regards
BLADE
PostPosted: Tue Aug 13, 2013 12:55 pm
It is hard for us to reproduce this issue as we do not have such configuration at hand (2 cards, 3 monitors). We'll search for possible causes.
Additional questions for you:
Does the issue depend on which port is used to connect the third display?
Has Mocap Studio presented you a dialog to choose the number of video cards to use and what have you chosen?
PostPosted: Wed Aug 14, 2013 1:08 am
Hi!
Thanks for the idea to deactivate the second graphics card.
This works on my PC as well.
And for the completeness and another reference:
I am working with one GTX 550Ti and one ATI Radeon HD 5570, with an 2*22" and 1*23" monitor setup..
The error was:
.NET: 2.0.50727.6407
OS: Microsoft Windows NT 6.2.9200.0
System.InvalidOperationException: An unexpected error has occurred.
bei Microsoft.Xna.Framework.Graphics.GraphicsDevice..ctor(GraphicsAdapter adapter, DeviceType deviceType, IntPtr renderWindowHandle, PresentationParameters presentationParameters)
bei #=q1DboDFqwrS_K2p4QLL1Cg4GtrbYC2FtpgZdqePRqQkCQRSHlluPDtONbe2IoNPiWLu5JydL85VFVcCIZE6I8Bg==..ctor(GraphicsAdapter #=qC4btAbPDUjOxVzX8Lwzhig==, PresentationParameters #=qrj6qGEuSEEZdQsj5hlYPNw==, IntPtr #=qPsXdOFeYb_1Xtnk_DrFu5A==)
bei #=qnR6R1HKASkNRa8WPI1uBlPUDypJXpTR63ma3NdUrf12Ze2HogYrGgFg2q_F9aYFh.#=qoSVuAaLxva01lkp1uKDC8cb84W2Gf1I_vGAPFmMg2h4=()
bei #=qnR6R1HKASkNRa8WPI1uBlPUDypJXpTR63ma3NdUrf12Ze2HogYrGgFg2q_F9aYFh.#=qA8JaYuTvGdBj43FrirpbQWvqNBFa7S89G1$f0iJZlKU=()
PostPosted: Wed Aug 14, 2013 2:03 am
Thanks for another report.
Multi-GPU support is in early stage in our software, so some errors are inevitable. The safe workaround here is to set using 1 GPU (Help > Manage GPU usage).
Keep reporting, and we will fix those errors in future releases.
PostPosted: Wed Aug 14, 2013 2:47 am
Then i will keep reporting:
Sorry, but the save work around, does not work.
The same error message (I think while flying over the text) comes again with opening the Studio.
There is no possibility at this step, to choose between the GPUs.
So the inbetween seems to be to deactivate one card, choose one gpu, and than you can activate the second card again.
PostPosted: Sun Aug 18, 2013 11:36 am
Hello, guys.
Could you please run the attached program on your PCs and post/send its output back to me? It will help greatly in resolving your issues.
Also, it will be terrific if you bother to do this with the different numbers of connected monitors.
EnumerateDisplays.zip [29.7 KiB]
Downloaded 823 times
PostPosted: Sun Sep 01, 2013 8:56 am
Same error here, I have 1 card: Geforce GTX 680 and 3 monitors.
System.NotImplementedException: The method or operation is not implemented.
at #=qVyjnvVH_cZqZpIv6zmjZLExk3YP6OaPlIJyTdUKgnHof2sMVFgoaUcLLqx9xRel9.#=qTSKoAIe1c64xzcGdlESG5g==(Int32 #=q_2AhMqeTg6QpxbzD0ULUVxxfkY1Z92UeDVJ_h9UVbZ8=)
at #=q307MfWrWJR0xjHgjK63$CsQfZIXsCcE7vgZaGdkIPmvrKnFMvkkscbxvzkObEQm8..ctor(#=qlfiSARJxOChlv_orYuq$rhdumSLdNlFAV9dVvVRrcFTkkyH5f6Svy5p_zCYyGW9n #=q8YGi3Fr5Q0UGqwZU7XcGvg==, ContentManager #=qPklqqRhYBNqQxEHJEakq3g==, Int32 #=q7Az_j3_wVUdmgKdFCSV2DA==, Boolean #=qYfde6EJRENyrky0KozJ9wjxFBhvB4nvGaBZ_lpaUBzs=, Int32 #=qesmuzpR5$rgy48Ab41KDAz4iN0gd_ZFFKoRnZjiHb58=, String[] #=qzc5Hv5aluChL13jylAmDvw==)
at #=qVyjnvVH_cZqZpIv6zmjZLExk3YP6OaPlIJyTdUKgnHof2sMVFgoaUcLLqx9xRel9..ctor(#=qlfiSARJxOChlv_orYuq$rhdumSLdNlFAV9dVvVRrcFTkkyH5f6Svy5p_zCYyGW9n #=qDcpcm0EizHJOqWq7HKI$WA==, ContentManager #=qcrT7ycP9kHjzBEMWq_7QmA==, Int32 #=qaAY99O9ovbpJyZuTu6eU3g==, Boolean #=q_fVoIFDqpa7W9TyYnXkJnh8krjmtSXzvjt5btDN5cw0=, Int32 #=qtsEMMu0UwrXgaz778IS9z7Hc17YPd8RHCpHmlLGWiO4=, String[] #=qZHI$QwUTpVH6$O92k8Q42A==)
at #=qyyNUcYHw2gxzDNIJlnPs$Q62ntqanw98xU6KrU2lcI2DFvAqQWYwguVEEgWs951_PpPhbGpiLA5DGWHkqMpWMQ==..ctor(#=qlfiSARJxOChlv_orYuq$rhdumSLdNlFAV9dVvVRrcFTkkyH5f6Svy5p_zCYyGW9n #=qzsRgNXJloBHg1Yd_1zGCSg==, ContentManager #=q$ApGVRH5Zs5SH_PFfHkZ$A==, Int32 #=qg4ZRwNox3ss4xppWsNmwtg==, String[] #=qIMTRh$GArnd8JuKG6_ylfg==, Int32 #=qg319mTr4iAMmZ$JeKcpwHFt2hD7QQA$aY3dpatwzXSk=)
at #=q_d_wxj6hvYFj05hPM_B$kPo2vCtzN3Rhe9EUk3HBc2CUISdaSiSHrR180tjcTr5TVt8zzhBG00Z8J4sFe1wSnQ==..ctor(#=qlfiSARJxOChlv_orYuq$rhdumSLdNlFAV9dVvVRrcFTkkyH5f6Svy5p_zCYyGW9n #=qTdbdUwNJUUnvNl8ScTskBQ==, ContentManager[] #=qh5L99obMDttMr5tcbJaKBrUZVfB$xcVyG18D5LIQpDc=, Int32 #=qN6XHo8u5B3s0FTJVzDzWBA==, String[] #=quPiD0qWWN56gjTMzM4xrQw==, Int32 #=qlaCBVstiNlX$0wLKeZgXfD0avzXeaVtbWyVSL9OYsdw=)
at #=qiO3pD8H9gotXHVjEX3BbcEzde5VMaQhiILOF7JpD_g7wmn1XnZ7R8F3k$afxFgcg..ctor(#=qlJBBhxWe5JeiKBQDnjU9PHLPELehv9nWb772gxrMu9okifwjzeRBootQVWLk8TAS #=q_eBhRrcqL1HNQAnrwl14Kg==, Int32 #=q3MHXWHq7FHUc86HinPgyIA==, String[] #=qLILQ0zNQfC6dSOksL8jFQg==)
at #=qHjZHMZRN0bt82YUTEN2chGgMs55g2nlwGpckVdbWBCGGXGWcB27eQumEUW1uPh8GYbwKNMgHheAs_Sb6rAc4xQ==..ctor(#=qlJBBhxWe5JeiKBQDnjU9PHLPELehv9nWb772gxrMu9okifwjzeRBootQVWLk8TAS #=qALceN0UqWBM$RCpHQX8h_w==, Int32 #=qAg36VVQzxWkrpkfzD$WGtQ==, Int32 #=qUcmelfpgNPjPEHPYSYrVOQ==)
at #=qlJBBhxWe5JeiKBQDnjU9PHLPELehv9nWb772gxrMu9okifwjzeRBootQVWLk8TAS.#=qwOAH9SsM9pk_goDep1LXb7GbdGb1ujc7eF2rSw9EQAA=()
at #=qlJBBhxWe5JeiKBQDnjU9PHLPELehv9nWb772gxrMu9okifwjzeRBootQVWLk8TAS.#=qJeOQeSNIX8HAc2jlZFLXbg==()
at -.dje_qKJ7RL7L59Q3W7E39DMDAVSLKKM2VMDG4FWCYPV7CDHTHTZEQGCJVL5DL9VXYMM4QMN6YQYTXHBA8E_ejd.#=qA8JaYuTvGdBj43FrirpbQWvqNBFa7S89G1$f0iJZlKU=()
at -.dje_qNPX5BCSF7JNWBBB5TDNVFV2JR9Z3DQS5EQP6G4MPTKBS9TTGRQ6A_ejd.#=q2wTCOrEnBYduTDTAPqxK4MizbAC7I_RyLgjQ_2vvBiw=(Object #=qnvD7aW3BWwtik2uv2NSnDQ==, RoutedEventArgs #=qPPu2SXlcfdLZiEJy6OXgDw==)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
at MS.Internal.LoadedOrUnloadedOperation.DoWork()
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
PostPosted: Sat Sep 07, 2013 12:15 pm
We've published fix: http://wiki.ipisoft.com/IPi_Mocap_Studio_Changelog#ver._2.4.1.156
