It is currently Tue Oct 27, 2026 11:32 am
PostPosted: Mon Jun 11, 2012 7:35 pm
Uh...where'd they go?
I was trying to set up my cameras and couldn't find the tilt controls. I opened the old version and set them where I wanted them, then restarted 2.0 and the Kinects switched back! Please tell me I'm just not finding them. If not, please put those controls back in.
PostPosted: Tue Jun 12, 2012 12:48 am
Are you talking about motor control in iPi Recorder? You'll find it on the Setup stage of Recorder tab. Move mouse pointer over camera picture and push the PROPERTIES button in the popup with screen controls. Then you'll jump to setup of this specific camera where you can adjust all its properties, including motor position. When finished, push the BACK button. Also, properties values will be restored on the next run of iPi Recorder.
We are looking for ways to make this operation more discoverable.
PostPosted: Tue Jun 12, 2012 10:44 am
Great, thanks for the quick response. Much appreciated.
PostPosted: Sat Aug 31, 2013 1:35 pm
I'm having an issue with this as well, there is no Properties button when the mouse is over the camera picture. Didn't know if this has to do with the slew of issues I had with initially setting up the Kinect. Eventually almost everything is working except the ability to control the motor.
If you have any ideas, that would be great. Thanks for your time.
-AJ
Users browsing this forum: No registered users and 89 guests
