| IPi Recorder keeps on crashing https://forum.ipisoft.com/viewtopic.php?f=5&t=8846 |
Page 1 of 2 |
| Author: | klaw12 [ Sat Sep 28, 2013 3:47 pm ] |
| Post subject: | IPi Recorder keeps on crashing |
After weeks of waiting, I finally got my Kinect for the 360. I wanted to test it (along with the trial iPi software) before I get an office from which to work on. I downloaded the recorder, installed it and all the drivers and stuff needed, and when the times come to run it, it crashes. I've followed the guide on the wiki, and still nothing. Problem: iPi Recorder crashes as soon as I try to open it. I'm using Windows Vista 64-bit. The error it gives me is a simply "...has stopped working." |
| Author: | vmaslov [ Sun Sep 29, 2013 12:53 am ] |
| Post subject: | Re: IPi Recorder keeps on crashing |
Hi Look for messages related to crash in the Windows event log. To open it: Start Menu > (right-click) Computer > Manage > (expand) Event Viewer > (expand) Windows Logs > Application. Do you have any other drivers for Kinect installed besides those which come with iPi Recorder? |
| Author: | klaw12 [ Sun Sep 29, 2013 10:51 am ] |
Nope, no other driver for the Kinect installed. Just one error on the log: Application: iPiRecorder.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.DllNotFoundException Stack: at Psdrv3GateManaged.Interop.Psdrv3Gate+Amd64.xnUSBInit() at Psdrv3GateManaged.Interop.Psdrv3Gate.Init() at Psdrv3GateManaged.UsbDevice.Init() at iPiRecorder.App.Main() |
| Author: | vmaslov [ Sun Sep 29, 2013 12:14 pm ] |
Just to ensure - have you installed the latest release of iPi Recorder (2.2.1.25)? Try to reinstall the program in any case. Are any errors reported during the installation? |
| Author: | klaw12 [ Sun Sep 29, 2013 6:28 pm ] |
I used two different links for the software: one from the wiki, and one from the download section (both are the same), so yeah, the latest. I've tried uninstalling, installing again. After restarting, without restarting, With a fresh download, with the same download. Same result. No, the installation has gone smoothly every single time. |
| Author: | vmaslov [ Mon Sep 30, 2013 1:46 am ] |
OK. Now please do two more things.
| Author: | klaw12 [ Mon Sep 30, 2013 10:25 am ] |
Yes, that file is there. The new installer doesn't help. It still crashes. |
| Author: | vmaslov [ Tue Oct 01, 2013 8:41 am ] |
Hi Try to install Microsoft VC 2010 Runtime: http://www.microsoft.com/en-us/download/details.aspx?id=14632 Does that help? |
| Author: | klaw12 [ Tue Oct 01, 2013 9:54 am ] |
Yes! It opens now at least. |
| Author: | vmaslov [ Tue Oct 01, 2013 10:12 am ] |
Cool! I recommend you to revert back to exe-installer (ClickOnce), as MSI installation does not support automatic updates. We will make necessary changes to distributions of the next releases to address this issue. Thanks for being patient :) |
