It is currently Thu Oct 29, 2026 8:08 am
PostPosted: Sat Jan 04, 2014 10:22 pm
Windows 7, latest updates, running latest MoCap Studio trial crashes on launch (won't start). Recorder working fine. Crash dialog text below.
I tried uninstalling and reinstalling MoCap Studio and same crash. Suggestions?
Cheers,
Brett
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at #=qqYupkjEjyOSRBpcoM8M$rBZ9VMdJnKt79LDoFM7NzHDlZuL6geTFdNs8vy6O9H$j.#=q2bRLRFmygOcpcEgaJbnB7Q==()
at -.dje_q8JSA8WULFJJRE3FHJN87VXKVQ8LZRUDWY7TPJ7NHS9RELRJEVZ44G4XT83NQ6JNV9XJFTD5GTHFD3_ejd.OnPaint(PaintEventArgs #=qez_RXkXhmk4k9HSHcCw3Yg==)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
iPiMocapStudio
Assembly Version: 2.5.1.159
Win32 Version: 2.5.1.159
CodeBase: file:///C:/Users/Bibby/AppData/Local/Apps/2.0/R239MJTA.16P/90L563JZ.OJN/ipim..tion_45b20dbe8f508542_0002.0005_5c5332f10eb6b53b/iPiMocapStudio.exe
PresentationFramework
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5011 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
PresentationCore
CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Deployment
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.5420 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
zx_d2c9cb824d834f6ab57aa19f9e784be0
PresentationFramework.Aero
Win32 Version: 3.0.6920.4902 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
Microsoft.Xna.Framework
Win32 Version: 3.0.11010.0
CodeBase: file:///C:/Windows/assembly/GAC_32/Microsoft.Xna.Framework/3.0.0.0__6d5c3888ef60e27d/Microsoft.Xna.Framework.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
WindowsFormsIntegration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsFormsIntegration/3.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
msvcm80
Assembly Version: 8.0.50727.4940
Win32 Version: 8.00.50727.4940
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4940_none_d08cc06a442b34fc/msvcm80.dll
iPiHelpers
Assembly Version: 1.0.0.4
Win32 Version: 1.0.0.4
CodeBase: file:///C:/Users/Bibby/AppData/Local/Apps/2.0/R239MJTA.16P/90L563JZ.OJN/ipim..tion_45b20dbe8f508542_0002.0005_5c5332f10eb6b53b/iPiHelpers.DLL
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
UIAutomationProvider
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationProvider/3.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
PostPosted: Thu Jan 09, 2014 8:53 am
From your other posts (about calibration) I see that you launched Mocap Studio previously.
Was that on another PC, or Mocap Studio stopped working on the same PC suddenly? Have you made any changes to your PC hardware/software configuration recently?
PostPosted: Thu Jan 09, 2014 8:57 am
When I was running the calibration evaluation, I saw it takes a long time. I have another Mac Mini with a Windows 7 bootcamp partition so I installed the trial on that so I can use my laptop while it ran.
But the software won't boot and dies on launch on the Mac Mini running Windows 7.
PostPosted: Thu Jan 09, 2014 9:08 am
What's the graphics card on Mac Mini? Have you installed the latest drivers for it?
PostPosted: Thu Jan 09, 2014 9:21 am
Yes, I wiped the whole machine and installed Windows 7, installed all the updates, and then Studio. Nothing else on the machine.
The graphic card isn't great. I'm not at the machine now, but Google search on the model says it's a NVIDIA GeForce 320M.
PostPosted: Thu Jan 09, 2014 11:09 am
Can you please run GPU-z and CPU-z on your Mac Mini to detect exact version of your CPU and video card:
http://www.techpowerup.com/gpuz/
http://www.cpuid.com/softwares/cpu-z.html
One possible explanation is that you have a Mac Mini with Intel CPU with iPi-incompatible integrated graphics and additional compatible Nvidia GPU, and your computer automatically switches to integrated graphics when running iPi Mocap. Switching to Nvidia GPU may help, but it is not clear how to do this on Mac Mini (Nvidia offers tools to switch GPUs on notebooks, but not on Mac Mini).
PostPosted: Thu Jan 09, 2014 11:32 pm
Thanks for your help.
Below is the screenshot I took from GPU-Z showing the popup menu open and only one graphics chip. The Mac Mini I'm using doesn't have an integrated GPU too.
My Mac Mini specs:
http://support.apple.com/kb/SP585?viewl ... cale=en_US
PostPosted: Fri Jan 10, 2014 2:42 am
Please try launching Mocap Studio several (5-10) times in a row to check whether this error is stable or occasional.
PostPosted: Fri Jan 10, 2014 4:14 am
10 times launched, 10 times crash. I did force install the latest nVidia drivers from last week and now at least the app is visible in the background (but is starting up still).
PostPosted: Fri Jan 10, 2014 7:34 am
From the screenshot I see that the diagnostic text for error is a bit different from what you've put in the first post. Can you post the new text here?
