6 cam frame rate issue
https://forum.ipisoft.com/viewtopic.php?f=5&t=8993
Author:  cuih0829 [ Thu Mar 13, 2014 12:48 am ]
Post subject:  6 cam frame rate issue
I have a dell T5500 workstation,i think it has three+ USB port ,but 4 cam work well ,6 cam only work under 30fs (at lest 3 cam)why? thanks 。
Author:  Greenlaw [ Thu Mar 13, 2014 4:34 am ]
Post subject:  Re: 6 cam frame rate issue
Do you have enough USB Controllers to accommodate the number of devices? The general rule of thumb is 2 PS Eye cameras or a single Kinect per Controller.
Be aware that the number of USB ports on your computer does not determine how many Controllers it has because multiple USB ports can be associated to a single Controller. Most computers have two Controllers which can potentially support 4 PS Eye cameras but probably not 6.
If this is the case, you may need add an additional USB controller card to your computer.
Author:  vmaslov [ Thu Mar 13, 2014 7:37 am ]
From the specs it looks that your PC has only USB 2.0 ports (no USB 3.0), that usually means there are only 2 USB 2.0 controllers.
As Greenlaw cited from the wiki, you need one USB controller per 2 PS Eye cameras. Thus, to work with 6 cameras at full speed, you need an additional USB controller.
Depending on the free expansion slots on your motherboard, you can install either PCI card with USB 2.0, or PCIe card with USB 3.0. Please see the bottom of the above wiki page for known compatibility issues for certain camera-controller pairs. Use this list to avoid possible problems when choosing USB controller to buy.
Author:  cuih0829 [ Thu Mar 13, 2014 7:19 pm ]
thanks,how can I know that how many USB controller in my computer,here is my computer snapshot ,
Author:  cuih0829 [ Thu Mar 13, 2014 7:27 pm ]
I saw wiki and knew only 2 USB 2.0 controller in my computer ,others are USB1.0.I'll try to buy PCI card ,thanks again.
Author:  Greenlaw [ Fri Mar 14, 2014 9:03 am ]
If you can, get a USB 3.0 card. Even though the devices themselves are not USB 3.0, you can still get better data throughput than with a USB 2.0 card.
