| Batch processing skips refine backward https://forum.ipisoft.com/viewtopic.php?f=5&t=9038 |
| Author: | Mikola [ Wed May 07, 2014 7:28 am ] |
| Post subject: | Batch processing skips refine backward |
Hi, I set up a batch with track forward (HQ), refine backward and jitter removal. When the batch is done, the refine pass has the same start and finish time. So obviously it was skipped. Setup is eight PS3 cams. Mikola |
| Author: | vmaslov [ Thu May 08, 2014 1:10 am ] |
| Post subject: | Re: Batch processing skips refine backward |
Hi, Mikola When you added the refine step to a batch, have you moved the current frame to the last frame of ROI? If not, then it's possible that refine step was recorded with starting frame equal to the first frame of ROI. Therefore, it covered only that single frame, which was executed quickly. If you saved the batch, you can simply check this by looking if the number in "frame" field for the step is equal to the left number in the "roi" field. |
| Author: | Mikola [ Thu May 08, 2014 2:18 am ] |
Hi vmaslov, placing the timeline marker at the end of ROI before adding refine backward to the batch did the trick. Thank you very much! Mikola |
