PostPosted: Mon May 26, 2014 5:17 pm
Hi there, I'm running into a startup issue...
I have recorded ok with 3 xbox kinect sensors but in Studio when creating a new project I select the movie clip and in the next window I only get the option to create an Action Scene, the Calibration option which I see when using my laptop and the demo version, isnt present when I use my desktop and the Standard version of Studio..
Is there anything I need to do to enable the calibration option?
I did note the "experimental" nature of this feature, but I did see the calibration option when testing the demo software out on my laptop yesterday so am hoping its nothing major maybe a driver issue?
Aaron
PostPosted: Mon May 26, 2014 8:03 pm
Solved.
I was only recording depth data not actual video. Video is required in order to calibrate.
PostPosted: Mon May 26, 2014 11:34 pm
Yes, in order to calibrate a triple sensor config, you need to record RBG data. Because the only supported calibration method is using a light marker.
I've made a clarification on this in the wiki article:
http://wiki.ipisoft.com/Getting_Started_with_Triple_Depth_Sensor_Configuration
