| recommended Usb Cards? https://forum.ipisoft.com/viewtopic.php?f=5&t=9063 |
| Author: | kernberg [ Tue Jun 03, 2014 2:02 am ] |
| Post subject: | recommended Usb Cards? |
Hi! I have some troubles with my Usb cards. I use 8 ps eyes and have now a mix between the mainboard usbs, and 2 quite old usb cards. one of the cards always makes trouble (there are no new drivers...). So I want to buy new cards. Are there any recommendations which work solid? Thank you! |
| Author: | vmaslov [ Tue Jun 03, 2014 4:38 am ] |
| Post subject: | Re: recommended Usb Cards? |
For PS Eyes, I usually recommend to get any card based on NEC USB 3.0 chipset. No problems with PS Eyes and NEC uPD720200 built-in my motherboard. There's one specific card mentioned here in the forum specifically for 8 cameras setup: http://forum.ipisoft.com/viewtopic.php?f=7&t=6824 I suppose, this one, but you may check with the original post's author. |
| Author: | kernberg [ Wed Jun 04, 2014 1:19 am ] |
Thank you :) I think I'll go with another NEC (already use one, works fine). The other card was a via 6212l and as I've seen on the page this is probably the worst garbage you could get :D Anther thought was why not simply connect 2 x USB 2.0 by a hub and go with that through one USB 3.0? I tried it, but it didn't work (always had framerates at 58fps). Shouldn't USB 3.0 have enough bandwidth for 2 cameras? Thanks |
| Author: | vmaslov [ Thu Jun 05, 2014 11:19 am ] |
kernberg wrote: Anther thought was why not simply connect 2 x USB 2.0 by a hub and go with that through one USB 3.0? I tried it, but it didn't work (always had framerates at 58fps). Shouldn't USB 3.0 have enough bandwidth for 2 cameras? USB 2.0 devices work with USB 3.0 controllers in backward compatibility mode, so they are limited to USB 2.0 bandwidth. Single USB controller is capable of handling 2 PS Eye cameras at 60 fps. But when connected with a hub, I suppose the hub itself can drain some bandwidth. |
