| Single Kinect Issues https://forum.ipisoft.com/viewtopic.php?f=5&t=9125 |
| Author: | Varrick [ Thu Jul 31, 2014 2:20 pm ] |
| Post subject: | Single Kinect Issues |
I recently downloaded this software and I love it! However I am only using one Kinect and there seems to be some trouble. When I track the motion, all is well at the beginning, but after a while the limbs start to do funky things, as shown here. http://i.imgur.com/T83THI1.png http://i.imgur.com/HvWukXL.png The squares accurately represent where my legs are but the model puts the legs in a different place. How do I avoid this problem using a single Kinect? If it's not easy will using a second Kinect solve the problem? Any help is greatly appreciated. |
| Author: | vmaslov [ Sat Aug 02, 2014 1:52 am ] |
| Post subject: | Re: Single Kinect Issues |
This is a common tracking error. Using more cameras (in this case, a second Kinect) greatly helps to reduce the number of errors. However, with some practice, such errors can usually be cleaned up with a small effort. http://wiki.ipisoft.com/Clean-up |
| Author: | Greenlaw [ Sat Aug 02, 2014 4:06 am ] |
In some cases it might help to stand slightly turned away from facing the Kinect--maybe 30-45 degrees? This way it may be possible for the Kinect to see the angle of your legs more accurately. I would avoid turning a full 90 degrees because then you're just exchanging for a different occlusion problem. Just a thought. Otherwise, as previously suggested, you will need a second Kinect for iPi Mocap Studio to see exactly what the legs are doing in this pose. G. |
