It is currently Sun Nov 08, 2026 7:33 pm
PostPosted: Thu Sep 11, 2014 9:16 pm
windows auto update installed Sep 2014 servicing stack update for Win 8.1. After that, iPiRecorder has a tough time loading. It takes a long time to get to the record screen with my kinect feeds. One of the kinects does not connect properly.
Update for Microsoft Windows (KB2989647)
I uninstalled these updates under Control Panel/Programs/Programs and Features/Installed Updates
Restarted my machine with automatic updates turned off, and iPiRecorder is back to normal.
Any thoughts? Definitely something to look into.
Thanks,
Adnan Hussain
http://www.madguru.com
PostPosted: Fri Sep 12, 2014 6:43 am
Thanks for reporting, we'll look into that.
PostPosted: Mon Sep 15, 2014 12:35 am
BTW, have not asked you, is that Kinect for Windows or for XBOX 360?
Is there any error shown in Device Manager for non-working sensor?
PostPosted: Wed Sep 17, 2014 12:39 pm
This was using Kinect for 360. I did not check the device manager.
PostPosted: Fri Sep 19, 2014 3:02 am
Hello!
We investigated this issue. Indeed on Windows 8.1 with latest updates there're some oddities of Kinect behaviour:
  • One time frame rate was about only 20 frames per second. But after reboot frame rate became good (30fps). And we can't reproduce such behaviour again.
  • In addition, if we unplug Kinect and then plug again, then it hangs up in "Not Initialized" state and can't be used. Again, only reboot helps.
Meanwhile, Kinect for Windows works fine without any issues.
PostPosted: Fri Sep 19, 2014 5:25 pm
Thanks for the update. Hopefully a solution can be found. I can only imagine how tough it must be to debug. Thanks for your efforts. I've noticed the same slowdowns in frame rates for kinects, freezing, or color or depth dropping out in recorder. I think there is an overall slowdown in Mocap Studio with these updates as well. I have to do further testing, but updates KB2989647 and KB2894856 might be ok. It is the third one from the last few days that may be the issue. I removed it, and things seem to be better. Will test further.
Adnan
PostPosted: Sat Sep 20, 2014 9:48 am
On further testing, I had to remove all updates security and otherwise for Windows 8.1 for the month of September in order to get things working as they should.
Adnan
Users browsing this forum: No registered users and 107 guests
