PS Move controllers crash 3.0 -
https://forum.ipisoft.com/viewtopic.php?f=5&t=9195
Author:  adamcloud [ Tue Nov 04, 2014 8:26 pm ]
Post subject:  PS Move controllers crash 3.0 -
I need to get the proper bluetooth dongle for my bluetooth-less laptop...
in the recorder V2, I could at least get 1 PS Move controller to read and work. Not 3, as I was hoping. Not sure what's been preventing me from making that work.
in the recorder V3, the recorder simply crashes and a very long error text document comes up. What's going on?:(
Author:  andrew [ Wed Nov 05, 2014 5:29 am ]
Post subject:  Re: PS Move controllers crash 3.0 -
Hello!
Can you please post more details about your configurations and error message text?
Author:  adamcloud [ Wed Nov 05, 2014 8:44 am ]
In the beginning, and is still the reigning champ of actually reading a Move controller, I used an old Kensington Bluetooth USB 2.0 adapter. Model #33348 : http://www.amazon.com/KENSINGTON-33348- ... B000BUEGX6
After reading up, I looked into other MotionJoy compatible dongles. I purchased the ASUS BT400 (http://www.newegg.com/Product/Product.a ... 6833320166) which was a bust and wasn't readable by MotionJoy, so no controllers would register. I went back to the store and after looking up on Wikipedia, I tried another dongle by TrendNet. The TBW-106UB (http://www.trendnet.com/products/prodde ... _TBW-106UB). This dongle was readable by motionjoy, but my Move controllers wouldn't read at all.
With the Kensington dongle; the first one I tried, I could get ONE Move controller to read with it but not more than one. This is only in ipirecorder V2. If I try to connect more than one Move controller, I get an error message in the recorder saying HID Error 121 for any and all controllers.
Getting to my point with Recorder V3,
The same steps mentioned above allow me to connect a single Move controller, but when I go to record, the following error message comes up:
iPi Recorder 3.0.0.31
OS: Microsoft Windows NT 6.2.9200.0 (64 bits)
.NET: 4.0.30319.18449
CPU count: 4
GC: workstation (Interactive)
Running in 64 bits
System.Windows.Markup.XamlParseException: Provide value on 'System.Windows.Markup.StaticExtension' threw an exception. ---> System.ArgumentException: '-.dje_qLXZ22QFGBEB39H7T8ATXBZL3TZZ36T7K5WHFEZM9FV57KNBRL8Q6UE8SHT4UDGM78936SJNUVNMHA_ejd.MinBatteryLevel' StaticExtension value cannot be resolved to an enumeration, static field, or static property.
at System.Windows.Markup.StaticExtension.ProvideValue(IServiceProvider serviceProvider)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CallProvideValue(MarkupExtension me, IServiceProvider serviceProvider)
at System.Windows.FrameworkTemplate.LoadTemplateXaml(XamlReader templateReader, XamlObjectWriter currentWriter)
at System.Windows.FrameworkTemplate.LoadTemplateXaml(XamlObjectWriter objectWriter)
at System.Windows.FrameworkTemplate.LoadOptimizedTemplateContent(DependencyObject container, IComponentConnector componentConnector, IStyleConnector styleConnector, List`1 affectedChildren, UncommonField`1 templatedNonFeChildrenField)
at System.Windows.FrameworkTemplate.LoadContent(DependencyObject container, List`1 affectedChildren)
at System.Windows.StyleHelper.ApplyTemplateContent(UncommonField`1 dataField, DependencyObject container, FrameworkElementFactory templateRoot, Int32 lastChildIndex, HybridDictionary childIndexFromChildID, FrameworkTemplate frameworkTemplate)
at System.Windows.FrameworkTemplate.ApplyTemplateContent(UncommonField`1 templateDataField, FrameworkElement container)
at System.Windows.FrameworkElement.ApplyTemplate()
at iPiWpfTools.VideoPanel.VideoPanel.CreateScreenContent(VideoPanelScreen screen)
at iPiWpfTools.VideoPanel.VideoPanel.CreateMissingScreenContent(VideoPanelScreen screen, Int32 row, Int32 column)
at iPiWpfTools.VideoPanel.VideoPanel.CreateMissingScreenContents()
at iPiWpfTools.VideoPanel.VideoPanel.RecreateContents()
at iPiWpfTools.VideoPanel.VideoPanel.Screens_CollectionChanged(IEnumerable oldItems, IEnumerable newItems)
at iPiWpfTools.VideoPanel.VideoPanel.OnScreensPropertyChanged(DependencyObject source, DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue)
at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange)
at MS.Internal.Data.PropertyPathWorker.UpdateSourceValueState(Int32 k, ICollectionView collectionView, Object newValue, Boolean isASubPropertyChange)
at MS.Internal.Data.ClrBindingWorker.ScheduleTransferOperation(Object arg)
at MS.Internal.Data.DataBindEngine.ProcessCrossThreadRequests()
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
So that's the problem I'm having in a nutshell. It's bad enough that I can't use recorder V3 with Move controllers, but it's worse that the application crashes when I try. Any answers to these problems would be awesome.
Author:  andrew [ Wed Nov 05, 2014 9:13 am ]
Oh! I see. We just reproduced this behaviour in one of our test environments. It's bug. We'll fix it and publish update in a couple of days. Sorry for this inconvenience! And thank you for reporting and details!
Best regards,
Andrew
Author:  adamcloud [ Tue Nov 11, 2014 8:07 am ]
Will we all be notified when the update is ready?
Would love to use V3 and this fixed bug:)
Author:  vmaslov [ Tue Nov 11, 2014 2:41 pm ]
An update is planned to be released tomorrow. We'll post news in this section, as usual. And in this thread too (if do not forget :)
Author:  andrew [ Thu Nov 13, 2014 12:35 pm ]
Fixed: release notes
Sorry for inconvenience!
