PostPosted: Tue Nov 25, 2014 3:47 pm
My Files:
IPiVideo: https://drive.google.com/file/d/0B3gaEi ... sp=sharing
IPiMotion: https://drive.google.com/file/d/0B3gaEi ... sp=sharing
Model Tpose: https://drive.google.com/file/d/0B3gaEi ... sp=sharing
DMX Tpose: https://drive.google.com/file/d/0B3gaEi ... sp=sharing
(not sure if you need these)
Calib: IPicalib: https://drive.google.com/file/d/0B3gaEi ... sp=sharing
Calib: IPscene: https://drive.google.com/file/d/0B3gaEi ... sp=sharing
Actor: https://drive.google.com/file/d/0B3gaEi ... sp=sharing
When assigning source bone 'LShoulder' to target bone 'shoulder_L' the program crashes with the following stacktrace:
iPi Mocap Studio version 3.0.1.169 [FREE TRIAL (9 days left)]
ENVIRONMENT
OS: Microsoft Windows NT 6.3.9600.0 (64 bits)
.NET: 4.0.30319.34014
CPU count: 4
GPU Information:
NVIDIA GeForce GTX 660 Ti (VendorID=10DEh, DeviceID=1183h, SubsystemID=28431462h, Revision=A1h)
Primary: yes, Integrated: no, Compatible: yes, Used: yes
Memory: 1.9 GB dedicated video + 0 B dedicated system + 2.0 GB shared system
Outputs: (1920x1200@60 R8G8B8A8_UNorm), (1920x1080@60 R8G8B8A8_UNorm)
Intel(R) HD Graphics 4600 (VendorID=8086h, DeviceID=412h, SubsystemID=D0001458h, Revision=6h)
Primary: no, Integrated: yes, Compatible: yes, Used: no
Memory: 32 MB dedicated video + 0 B dedicated system + 1.7 GB shared system
Outputs:
PROCESS
GC: Workstation (Interactive)
Running in 64 bits
EXCEPTION
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.Generic.List`1.get_Item(Int32 index)
at #=qKsrmCGdY2MpEa6XKdpg2qU1Q8_29dLLvCgFibSoUiFcRR7ChE7drvvSmv6MO1r7SLSoHJs28OaR4kPxSYe7bDw==.#=qmuT28_lOj8KJMh_u20C99Q==(Bone3D #=qpglbwyyJKmI3pdnlz_g7rw==)
at #=qKsrmCGdY2MpEa6XKdpg2qU1Q8_29dLLvCgFibSoUiFcRR7ChE7drvvSmv6MO1r7SLSoHJs28OaR4kPxSYe7bDw==.#=qMydbL1knCroPX6JepDdo8omAddJtPZBx4uDXNWGQSVs=()
at #=qKsrmCGdY2MpEa6XKdpg2qU1Q8_29dLLvCgFibSoUiFcRR7ChE7drvvSmv6MO1r7SLSoHJs28OaR4kPxSYe7bDw==.#=qAmLgfCUWQ8xJhEeXHErzIA==()
at #=qPhnXuLDEUwdV1$oK8Se4EFUa1CvTUHd5Ana0dLO56Nagxtgn_3eRz4LCiYhRloYm.#=qP8UC9Iwv3Ccr4kXpAkHSNVAq4mzAs7EwFRkHkn6Vwug=()
at -.dje_q7WU4K5VB78UYSF6KC5MS4P38A74N3DG2VSPP8WNFJMXU25FCSDCA_ejd.#=qQdnV6c9P7frzFtQVQdobhi4IW$coC3rDQfW2jps4WQevdNLOFPlmAlq_PA13iZeH(Object #=q9gSDT9TzXqXQEV56dpmAOA==, EventArgs #=qR2f49GLpp7S5f$7Sw2QCGQ==)
at -.dje_qYX7MH2ZHU7EAHD2FEMBTJ5LCK2LNCD749VS6ACNPGQYT9U47WGR7SHZDERL6VPKWJHXUXZKHLUGQJX7DP4H2SXTTEA93LV76F6MK7NQ_ejd.#=qetU09BVYkyguYJUHnh2rC3PBZObty7C5H2eoBiCzGoQ=(Object #=qrdzXzjOiOnMRH9M0Wd_IAA==, SelectionChangedEventArgs #=qqU2k0$ffCggJjgu9Eejxog==)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.Controls.ComboBox.OnSelectionChanged(SelectionChangedEventArgs e)
at System.Windows.Controls.Primitives.Selector.SelectionChanger.End()
at System.Windows.Controls.Primitives.Selector.SelectionChanger.SelectJustThisItem(ItemInfo info, Boolean assumeInItemsCollection)
at System.Windows.Controls.ComboBoxItem.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
PostPosted: Wed Nov 26, 2014 5:29 am
Hello, thanks for reporting the issue
The problem is with the bone structure of your character. Our motion transfer expects bones organized similarly to our model. That is:
clavicle => shoulder => forearm
In your character, the best match for our 'Shoulder' bone is 'bicep':
clavicle => bicep => elbow
Try using the mapping profile I have attached to this post.
We will update the software to prevent app crash for such "inappropriate" bone mappings.
File comment: Fixed motion transfer profile
davion_tpose_fixed.zip [570 Bytes]
Downloaded 824 times
PostPosted: Wed Nov 26, 2014 6:58 am
What a silly mistake, thanks I appreciate the help!
Users browsing this forum: No registered users and 140 guests
