Very slow (program)
https://forum.ipisoft.com/viewtopic.php?f=5&t=9337
Author:  yoyomon99 [ Fri Apr 17, 2015 5:19 pm ]
Post subject:  Very slow (program)
The actual program itself is running very slowly, it takes 5 min just to start up, and another 10 min to load the file. When exporting it takes 20 min for it to open the winder to choose a destination to export.
Author:  vmaslov [ Sat Apr 18, 2015 9:19 am ]
Post subject:  Re: Very slow (program)
Do you run it on Windows 10 Preview?
If so, the problem may be caused by a new version of .NET Runtime that comes with this OS. It is not polished yet and has both performance and compatibility issues.
What's your hardware specs?
Author:  yoyomon99 [ Sat Apr 18, 2015 9:26 am ]
Yes I am running windows 10, is there any way to fix this, without downgrading to 8.1. And radeon r7 260x, 8gigs ram, amd 760
Author:  vmaslov [ Sat Apr 18, 2015 10:41 am ]
I don't know the fix, and suggested reason for the issue is just my speculation.
Another option may be the way that you've fixed crash at app start. If you completely uninstall and the install Mocap Studio, will it crash again or run slowly?
Author:  yoyomon99 [ Sat Apr 18, 2015 12:49 pm ]
I have tried to uninstall and reinstall multiple times, with no sucses.
Author:  yoyomon99 [ Sat Apr 18, 2015 9:06 pm ]
Post subject:  Re:windows 10
I was able to deactivate .NET 4.5 and just use 3.5, works perfectly. Thank you very much.
Author:  vmaslov [ Mon Apr 20, 2015 1:45 am ]
Actually, both Recorder v3 and Mocap Studio v3 require .NET 4.5. Windows 10 includes .NET 4.6 preview, which is formally backward compatible with 4.5.
So you must have done something else than uninstalling .NET 4.5. Anyway, good that program works now.
Author:  yoyomon99 [ Mon Apr 20, 2015 12:19 pm ]
Hm, that's all I did. I disabled 4.6, and enabled 3.5.
