| Help with slow computing https://forum.ipisoft.com/viewtopic.php?f=5&t=9354 |
Page 1 of 1 |
| Author: | wfsteele [ Tue May 05, 2015 10:28 pm ] |
| Post subject: | Help with slow computing |
Forum, Looking for help and tips on very slow computing. My computer speeds up as it crumches data, but is still very slow. With Head tracking, I am getting 8.0 to 2.8 secs/frame. GPU loading for both GPUs is always less than 27%, CPU loading is always under 12%. Any thoughts on how to make this faster are very appreciated. The only strange thing on my system is both monitors rotated to portrait (tall). iPi Pro + Biomech 3.2.0.182 Manufacturer Dell Inc. ------------------------------------------------------ Model Precision T7610 Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz, 12 core (2x, 24 core total) Total amount of system memory 16.0 GB RAM Windows 7 Professional 64-bit operating system Storage -------------------------------------------------------------------------------- Total size of hard disk(s) 745 GB Disk partition (C:) 220 GB Free (279 GB Total) OS Disk partition (D:) 439 GB Free (466 GB Total) Data Disk Graphics-------------------------------------------------------------------------------- Display adapter type NVIDIA GeForce GTX 770 (2x) Total available graphics memory 4096 MB Dedicated graphics memory 2048 MB Dedicated system memory 0 MB Shared system memory 2048 MB Display adapter driver version 9.18.13.4752 Primary monitor resolution 1200x1920 Secondary monitor resolution 1200x1920 DirectX version DirectX 10 ??????????????????????? |
| Author: | vmaslov [ Wed May 06, 2015 3:45 am ] |
| Post subject: | Re: Help with slow computing |
Hi What are the performance numbers when using a single GPU in Mocap Studio? |
| Author: | wfsteele [ Wed May 06, 2015 3:14 pm ] |
Do I need to physically take the card out, or just uncheck it in iPi Mocap studio? |
| Author: | wfsteele [ Wed May 06, 2015 3:38 pm ] |
With the 2nd card unchecked, processing is much better. Head Tracking 2.051-1.161 Secs/frame No Head Tracking 0.809-0.631 Secs/frame |
| Author: | wfsteele [ Thu May 07, 2015 1:15 pm ] |
GPU loading was up to 65.5% as well. |
| Author: | vmaslov [ Fri May 08, 2015 2:20 pm ] |
Thank you for the feedback. We have already noticed a decrease of performance on one of our dual-GPU configurations and are working on a fix currently. We'll notify you when we have a beta version for testing. |
| Author: | wfsteele [ Thu May 14, 2015 11:07 am ] |
Vasili, Thank you for the response. Please let me know if there is any data I can post, or tests or Beta's I can help you with. Also, a question of philosophy and your programming methods: In general, do you recommend 1x $400 GPU or 2 $200 GPUs for performance and speed of processing? I am not sure if this question has an answer without knowing how your team thinks about distributing load across the GPUs, and then re-combining and re-sync'ing the work streams. I assumed 2x cards at half the price would be a better option, and built my system that way. |
| Author: | vmaslov [ Fri May 15, 2015 1:20 am ] |
Generally, we recommend the opposite: one high-end GPU is better than two mid-range GPUs. With current algorithms in our software 2 GPUs provide at most 1.6 times improvement over 1 GPU of the same model. Moreover, with "light" camera configs like 1 Kinect or 3-4 PS Eyes dual GPUs give no advantage and may actually perform worse. Because in this case computations are not so intensive to fully utilize even a single GPU, and multiple GPUs always require some overhead to distribute the payload. |
| Author: | vmaslov [ Sat Aug 08, 2015 7:01 am ] |
V3.2.3.190 contains performance improvements for multiple GPUs which may solve this issue. |
