No Slave Found Error
https://forum.ipisoft.com/viewtopic.php?f=5&t=9418
Author:  yingfan [ Wed Aug 19, 2015 4:37 pm ]
Post subject:  No Slave Found Error
Hello all,
I have been having difficulties trying to use the distributed recording aspect of the iPiSoft Recorder. I have two Kinect v2 connected, one to each computer. Both computers were connected to the same network. However, when I tried detecting the other computer through the slave mode, the master computer could never detect any, it would just be "no slaves detected."
I suspected that the network may be blocking the ports that needed to be used as it was on a company network so I set up a hotspot on a phone instead (Galaxy Note 2) and connected each computer to the hotspot. However, the problem persisted and the computer couldn't detect the other.
I have also tried ad hoc network and setting up a virtual router.
I have checked to make sure that the windows firewall has iPiSoftRecorder allowed through any TCP ports. I'm running this on Windows 8.1 (both laptops).
Is there anything else that I can try, any advice or ways to try to find/solve the problem?
Thank you very much!
Author:  vmaslov [ Fri Aug 21, 2015 9:20 am ]
Post subject:  Re: No Slave Found Error
Hello
Maybe, you have some anti-virus software that also has firewall capabilities?
FYI, incoming TCP connections should be allowed on a slave PC only. Master PC only makes outgoing TCP connections. For slave discovery, broadcast UDP packets should be allowed on the network.
Author:  Snapz [ Sat Sep 12, 2015 11:44 am ]
This might be a silly question, but you did click the "Enter Slave Mode" button on the slave computer first?
Maybe by now you have gotten it working properly, but...
Both computers have to have their firewalls set to allow connection from one another, or to quick test, just disable firewalls on each machine to check if a connection is even available first.
Being a company workstation, no telling what their policies are set to, but the Hot-spotting as described should work.
Hope you got it working properly with firewalls on both machines enabled though.
