ipisoft.com
https://forum.ipisoft.com/
Really slow tracking with acceptable GPU card
https://forum.ipisoft.com/viewtopic.php?f=5&t=9499
Page 1 of 1
Author:  ocsi01 [ Sat Jan 09, 2016 5:26 pm ]
Post subject:  Really slow tracking with acceptable GPU card
I'm evaluating the iPi Studio 3 since a few weeks and today I'm starting tracking phase in my project.
I'm using an iMac running Windows 10 (Phew.. I know..) With an NVidia GeForce GTX 660M.
Last night I opened one of my captured video, first time on this computer and did a short tracking. I don't know what was the speed, but around 1 sec per frame for 2 actors (with 3 Kinects). ( That speed would be fine for me...)
However today my tracking is way much slower. Originally it was 0.036 FPS, with some changes in GPU settings now I have 0.045, which is still terrible.
-I have only 1 GPU, so no integrated Intel integrated card to switch off.
-Based on GPU-Z my GPU load jumps up from 0 to 98% when I'm starting the tracking. I assume it means the right GPU is used and it is "completely" utilized.
-I turned windows power options to high performance
As I said, just a day before, I've got a much better speed on the same machine. I can't recall any big change since then.
Any ideas what to check?
File comment: GPU Performance while tracking
Author:  vmaslov [ Mon Jan 11, 2016 1:52 am ]
Post subject:  Re: Really slow tracking with acceptable GPU card
Do you experience this speed degradation on the same project and tracking settings, or between different projects/settings?
Check whether video driver has been updated without you noticing it.
Author:  ocsi01 [ Thu Jan 14, 2016 4:41 pm ]
I've a set of videos which are part of the same homework, but they are tracked in different projects.
I never managed to get back to the speed what I had originally ( I did not saved that project, so I can't even retry it.).
Since then I usually get a <0.1 FPS, which is way under anything expected. I have a 3 month licence... the really slow tracking speed will cause a huge risk on my project.
Author:  vmaslov [ Fri Jan 15, 2016 6:14 am ]
What's shown in Manage GPUs dialog in Mocap Studio?
Is there any power management setting in NVIDIA Control Panel which you can set to maximum performance?
Author:  ocsi01 [ Fri Jan 15, 2016 2:44 pm ]
I've checked the NVIDIA control panel but did not round any GPU power settings. I'm on an iMac ( not a laptop) so constantly plugged in.
The manage GPUs shows 1 and only 1 GPU, the NVIDIA card. ( No integrated intel card.)
Author:  vmaslov [ Sun Jan 17, 2016 2:13 am ]
Try installing different versions of drivers for your GPU. You can get the list here (use Manual Driver Search section):
http://www.geforce.com/drivers
Just in case, aren't you running Windows in some sort of virtualized environment? From your info it looks like normal OS boot, but I'm asking to be sure.
Author:  ocsi01 [ Sun Jan 31, 2016 7:42 am ]
I have a fresh install of windows 10 on my iMac. I have DualBoot, so the Windows is directly booting after the windows, not from a virtualised environment.
I'll give a try to other drivers... however this is still really disappointing.
Author:  vmaslov [ Mon Feb 08, 2016 8:09 am ]
Please try to track more "simple" videos. Single actor, with 1-2 depth sensors. What performance do you get in that case?
FYI, our estimation for 3 Kinects / 2 actors video on GTX 660M (with default tracking settings) is 0.2 fps. The estimation is based on GPU performance benchmarks and known tracking speed for several tested GPUs.
http://www.phpbb.com/
