It is currently Sat Oct 17, 2026 2:15 pm
Post a new topicPost a reply Page 1 of 3   [ 23 posts ]
Go to page 1, 2, 3  Next
PostPosted: Thu Mar 24, 2016 8:25 pm
Keep getting 2 static pictures when using 2 kinects. Its fine when i use them separately.
Tried to switch ports but useless.
PS: Yestreday it worked fine on almost every combination of usb ports.
PostPosted: Thu Mar 24, 2016 9:20 pm
I'm assuming you're using the older Kinect. Do you have separate USB controllers for each Kinect? I don't think you can run two on a single controller, probably not reliably anyway.
PostPosted: Fri Mar 25, 2016 1:42 am
Maybe there are multiple drivers for Kinect on your PC, and they conflict.
Try to uninstall all items from Add/Remove Programs which contain the word 'Kinect'. And then install Kinect SDK v1.8.
PostPosted: Fri Mar 25, 2016 6:25 am
Still the same.
I even tried to install another kinect drivers, but the problem stays.
And there cant be problems with usb ports, since i have 4 usb-controllers
What i have installed so far:
PostPosted: Fri Mar 25, 2016 6:31 am
Problem may be not with the number of USB controllers (if you're sure about it), but with compatibility.
For example Kinect v1 has known compatibility issue with Intel 8x/9x chipset family USB controller.
PostPosted: Fri Mar 25, 2016 6:57 am
Maybe. I have quite a new PC(
But still i dont understand, how did it work before?
I figured out.
If i chose Depth only - both cameras will work. Is it enought to work?
PostPosted: Fri Mar 25, 2016 1:38 pm
That does make it sound like a controller issue, either compatibility or you have two connected to one compatible controller (although I'm not 100% sure you can connect two Kinects to one controller.) If you disconnect one of them, can the other one suddenly handle both depth and RGB? If so, that might present some clues about where the problem is.
As for whether it's necessary to capture the RGB stream, it depends.
In tracking, I've found RGB is helpful as visual reference in certain situations but it's not absolutely needed.
In calibration, if you're using a maglite then, yes, RGB is necessary, but it's not needed if you use the plane method.
PostPosted: Fri Mar 25, 2016 5:31 pm
Same issue I always had when trying to run 2-Kinect 360, can only run 2 in Depth only mode on 640 x 480 with Studio 2 version.
I never tried 2-Kinect 360 on Studio 3 version.
PostPosted: Fri Mar 25, 2016 5:45 pm
That's strange because I never had that issue with 360--I always recorded from both devices with RGB enabled.
Well, these were actually the original Kinect for Windows sensors which did have a few technical differences with the XBox 360 model but I don't think that would cause this issue. I dunno...maybe.
PostPosted: Fri Mar 25, 2016 6:18 pm
Didn't the K360 only have pic-n-pic RGB viewing for dual or more cams in Studio 2?
Couldn't get the full side by side on monitor.
I remember having this issue with Studio 2 and dual Kinect 360 though.
Users browsing this forum: Baidu [Spider] and 52 guests
