| Static Images when using 2x Kinect (360) https://forum.ipisoft.com/viewtopic.php?f=5&t=9721 |
| Author: | captainlonestar [ Fri Feb 24, 2017 3:12 pm ] |
| Post subject: | Static Images when using 2x Kinect (360) |
Not sure what the issue is. It'll work briefly then cut out and be unrecognizable and/or appear as a black screen. Then it'll only work on 320x240 resolution. Any ideas? I'm pretty frustrated. It worked fine with one kinect now it's giving me issues... I currently have two adapters attached to the two kinects. |
| Author: | Snapz [ Fri Feb 24, 2017 8:31 pm ] |
| Post subject: | Re: Static Images when using 2x Kinect (360) |
... If you have RGB pic-n-pic turned on in set up, try using only depth 640x480. ... |
| Author: | vmaslov [ Sun Feb 26, 2017 11:08 am ] |
Try plugging the second Kinect into all available USB ports, checking how it works with each one. |
| Author: | Snapz [ Sun Feb 26, 2017 11:20 am ] |
... Yes, good point, I just took it as the sensor and port worked for individual testing before hand. ... |
