thank you very much for the quick response. I will download the sample video and see if automatic processing will get through without issues.
For clarification, of what I believe might be an issue with my Kinect 2 I attach two images taken at the same location.
As you can clearly see, the kinect_1.png shows almost no yellow, whereas the kinect_2.png has a lot of yellow in critical areas (like the floor).
Kinect 1 (old)
Kinect 2 (new)
Do you believe this can be normal with the kinect 2 ? Or do you think it is malfunctioning. When I looked at the how to record video from ipi it was explained that yellow means no depth information and should be avoided....only, I have absolutelly no sucess avoiding this with the Kinect 2. The Kinect 1 shows no yellow in the exact same location.
Tracking wise I already switched back to kinect 2, as the results, even, with a might be defective sensor, still seem to be a little bit better.
I would like to figure if it would be worth it to go and get a new kinect 2, to solve this or if it would be a waste of money.
Thank you !
