It is currently Sun Nov 08, 2026 6:12 pm
PostPosted: Thu May 16, 2013 6:33 am
Hello,
Kindly anyone guide or redirect me to MULTI PS MOVE CONTROLLER Pairing (BLUE TOOTH) tutorial page for win 8 or win 7.
I can pair only one ps move controller at a time using motion in joy plugin in WIN 8.Additional connections creating conflict in IPISOFT Recorder.
Thanks in advance.....
PostPosted: Fri May 17, 2013 12:24 am
Hello
What kind of conflicts do you mean?
In Win7, pairing is done in iPi Recorder via the Add New button on the Devices screen. You just pair all your PS Moves one by one.
In Win8, this is done with MiJ DS3 Tool. You install MiJ driver for BT adapter, then for each PS Move you connect it via USB, install MiJ driver, and pair with adapter.
PostPosted: Sat May 18, 2013 9:29 am
Hello,
Thanks for your reply.
i have tried the method you mentioned for WIN 7. Which actually paired all
the three ps controller thru USB and later thru bluetooth.
Initially all the three ps controller detected thru bluetooth in IPI Recorder and worked fine for 30
SEC,after 30 Sec ps controllers shuts down automatically.
It shuts down saying
*CONTROLER 1 "The device is not connected"
*CONTROLER 2 "A device attached to the system is not functioning."
But single ps controller connection are working fine.
PostPosted: Tue May 21, 2013 4:22 am
Hello,
kindly someone shed some light on the issue...
Is i'm missing something on the process.
Even i tried with the fully charged PS Move Controllers.Still its not working.
thanks in advance...
PostPosted: Thu May 23, 2013 1:06 am
It may be the problem with your BT adapter - e.g. it's not suitable for handling more than 1 PS Move properly. I can recommend the ASUS USB-BT211 dongle which proved to work good with up to 4 PS Moves.
Also, if you have any 3d party BT software/drivers, try uninstall them, then install your BT adapter (if it's not built-in).
PostPosted: Thu May 30, 2013 10:47 am
Thanks for your support.ASUS BT 211 Adopter solved the issues.
Users browsing this forum: No registered users and 42 guests
