It is currently Sun Nov 08, 2026 1:45 pm
 Post subject: running ?
PostPosted: Tue Nov 24, 2015 3:01 am
Hi there,
It's possible to capture someone running and put it on a a animation ?
If it's possible, how to do it because if I understand the most large you can have is 20 by 20 feet ?
Thank you for the help !
 Post subject: Re: running ?
PostPosted: Tue Nov 24, 2015 5:02 am
Yes, you can capture running motion. And you're correct that the range is limited to a capture area which is usually about 20x20 feet when using PS Eye cameras.
First, think whether you actually need a very long motion. Maybe, you only need a couple of steps and then loop them.
Also, you may experiment with camera placement to get a longer capture area specifically for running. Something like 10-12 feet wide corridor with cameras along the sides.
PostPosted: Tue Nov 24, 2015 6:07 am
Thank you for the answer,
Well it's not more easy to do with a travelator ?
PostPosted: Tue Nov 24, 2015 7:13 am
You can use treadmill or something similar to capture running. However, in this case you won't get correct movement of a character in the scene. It will be sliding on the ground instead of moving. You'll need to add translation to an animation manually in your animation software.
Users browsing this forum: No registered users and 28 guests
