It is currently Sun Nov 08, 2026 1:43 pm
PostPosted: Fri Feb 02, 2018 3:49 pm
I´m trying to use a Kinect v2 in Windows on an iMac but can´t even get it to recognized, the LED doesn´t even turn on (the Green LED does turn on in Mac OS X)
Any clue?
Information:
Kinect Configuration Verifier
USB Controller: "Unknown USB 3.0 port detected. Your USB configuration may support Kinect for Windows"
Kinect Connected "No Kinect for Windows v2 sensor detected"
Kinect Studio
Doesn´t show anything
The computer is an iMac 17,1 "Core i7" 4.0 27-Inch Aluminum (Retina 5K, Late 2015/Skylake) with four USB 3.0 ports
https://everymac.com/systems/apple/imac ... specs.html
The Device Manager shows (transating from spanish):
In the Universal Serial Bus Part:
Root USB hub (USB 3.0):
Microsoft controller 10.0.16299.64 (24/10/2017)
C:\WINDOWS\system32\DRIVERS\USBHUB3.SYS
USB generic hub
USB generic hub
Intel(R) USB 3.0 - 1.0 eXtensible host controller (Microsoft)
Bus PCI 0, device 20, function 0 Microsoft controller 10.0.16299.125 (07/12/2017)
C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS
Composed USB device
Composed USB device
Controlador de host eXtensible Intel(R) USB 3.0 - 1.0 (Microsoft)
In the Other Devices Part:
(Yellow warning size) Unknown Device
(Yellow warning size) Xbox NUI Engine
PostPosted: Fri Feb 02, 2018 4:10 pm
Any clue?
Information:
Kinect Studio
USB generic hub
USB generic hub
Composed USB device
Composed USB device
Aditionally, under Mac OS X, I get this information about the USB hardware:
Hub:
ID del producto: 0x005a
ID del fabricante: 0x0409 (NEC Corporation)
Versión: 1.00
Velocidad: Hasta 480 Mb/s
ID de la ubicación: 0x14300000 / 3
Corriente disponible (mA): 500
Corriente necesaria (mA): 100
Corriente operativa adicional (mA): 0
Xbox NUI Camera:
ID del producto: 0x02ae
ID del fabricante: 0x045e (Microsoft Corporation)
Versión: 1.0b
Número de serie: A00366A16506046A
Fabricante: Microsoft
ID de la ubicación: 0x14330000 / 10
Corriente necesaria (mA): 16
Xbox NUI Motor:
ID del producto: 0x02b0
Versión: 1.07
Velocidad: Hasta 12 Mb/s
ID de la ubicación: 0x14320000 / 6
Xbox Kinect Audio, © 2011 Microsoft Corporation. All rights reserved.:
ID del producto: 0x02ad
Versión: 1.00
Número de serie: A44886D04130046A
ID de la ubicación: 0x14310000 / 9
PostPosted: Sat Feb 03, 2018 9:52 am
Do you have the Kinect v2 SDK installed, checked the box when you installed the iPi Recorder?
PostPosted: Sat Feb 03, 2018 2:49 pm
Thanks Snapz, yes, I did that.
I’ve uninstalled, reinstalled, rebooted with only the Kinect plugged in the USB ports...
I suspect the USB 3.0 hub might not be compatible with Kinect that’s why I wanted to make sure that this specific iMac model works for someone before investigating more in depth.
Users browsing this forum: No registered users and 30 guests
