Joined: Wed Jan 11, 2012 6:12 am Posts: 2297 Location: Moscow, Russia
More cameras do not add capture space as an actor should be visible in all cams simultaneously. And it's more or less the same for both Kinect models - about 2.5x2.5 meters. Probably slightly more for Azure Kinect due to its wider view angle (an actor can get a bit closer to a camera). If you need to capture extended motions consider using RGB cameras (PS eye is the cheapest option). The process with RGB cameras is more complicated though.
