PostPosted: Sun Dec 13, 2020 7:14 am
Hi! Let me describe the problem I encountered. We have been using a program to animate the human body for some time now. For our task, we need to get a skeleton for each frame against the background of the RGB video.
And if you can get both separately, thank you for this opportunity. However, synchronizing the 3D skeleton and the background image, for this skeleton for each frame, is a rather difficult task. I mean - using the results of the program (sceleton like FBX and RGB video from the camera)
Perhaps access to Mockup Studio 3 API can solve my problem. Namely, to issue for each frame of the RGB an image and an animation frame of the skeleton(3D), sync with each other. Attached picture for example.
Perhaps I am explaining a little confusedly, sorry. Thank for advance!
PostPosted: Sun Dec 13, 2020 8:03 am
We have no API for getting any frame data so far.
If you only need to get a skeleton rendered over an RGB (no coordinate data) then check workflow suggested here
http://forum.ipisoft.com/viewtopic.php?p=23794#p23794
PostPosted: Sun Dec 13, 2020 8:53 am
Thanks for answer, but I also need a coordinate data. May be any advice?
