| Is there any quality different between basic and pro? https://forum.ipisoft.com/viewtopic.php?f=6&t=10501 |
| Author: | Baytbty [ Tue Nov 01, 2022 5:04 am ] |
| Post subject: | Is there any quality different between basic and pro? |
I am planning for high quality mocap animation. after seeing ipisoft demo by using duel azure Kinect ( https://youtu.be/lzkf-em00mo ) i was surprise by the quality yet i wonder dose pro version improve the quality overall if i was in room and do a 2 test of duel azure Kinect one in basic and other in pro is there any noticeable quality? |
| Author: | andrew [ Tue Nov 01, 2022 11:53 am ] |
| Post subject: | Re: Is there any quality different between basic and pro? |
Hello Baytbty, Thank you for your questions. Baytbty wrote: yet i wonder dose pro version improve the quality overall Basic version supports up to two depth sensors, while Pro version supports up to four depth sensors. Also, Pro edition can track multiple actors. More information can be found here. Baytbty wrote: if i was in room and do a 2 test of duel azure Kinect one in basic and other in pro is there any noticeable quality? No, when you use two depth sensors in both editions results are expected to be almost the same. That is, if you're going to use two depth sensors (dual Kinect configuration) to track single person, your choice is Basic edition. |
| Author: | Baytbty [ Tue Nov 01, 2022 12:55 pm ] |
andrew wrote: Hello Baytbty, Thank you for your questions. Baytbty wrote: yet i wonder dose pro version improve the quality overall Basic version supports up to two depth sensors, while Pro version supports up to four depth sensors. Also, Pro edition can track multiple actors. More information can be found here. Baytbty wrote: if i was in room and do a 2 test of duel azure Kinect one in basic and other in pro is there any noticeable quality? No, when you use two depth sensors in both editions results are expected to be almost the same. That is, if you're going to use two depth sensors (dual Kinect configuration) to track single person, your choice is Basic edition. Thanks for your help, may i ask you about fingers tracking and how it works and which camera does it work with? Thanks again for your time. |
| Author: | andrew [ Thu Nov 03, 2022 5:17 am ] |
Baytbty wrote: Thanks for your help, may i ask you about fingers tracking and how it works and which camera does it work with? Current version of iPi Mocap Studio does not support fingers tracking, but has tools for key framing of hands. |
