It is currently Sun Nov 08, 2026 3:17 pm
PostPosted: Mon Jul 24, 2023 11:00 pm
I purchased iPi Mocap a few years ago and have been able to successfully capture animations using my two Kinect V2 cameras. For the first time I am running into an issue.
I am trying to record a sword animation from a very specific stance (I can't use anything premade). The setup does not capture the orientation of my hand so the sword isn't positioned properly.
I read that you can use a motion controller to capture the hand orientation. So I tried using a PS Move controller. I was able to get it connected and apparently working in iPi Recorder, but it did not seem to have any effect. The angle of the sword was still wrong.
I tried using the Switch Joy-Cons, I could not get them to pair with my PC. And then I tried an old Wiimote, but ran into bluetooth issues.
What is the best way to record the correct orientation of the sword?
I was messing around trying other animations and they seemed to work fine so I think my Kinect setup is ok:
PostPosted: Tue Sep 05, 2023 7:20 am
Hello virtualdestructor,
Thank you for your question and sharing this great pics. Sorry for the silly question, but did you follow this guide? There are two the most important things:
  • first, to align motion controller(s) with 3D scene orientation (in horizontal plane)
  • then, to apply motion controller(s) data to appropriate body part (right hand, in your case)
Users browsing this forum: Google [Bot] and 41 guests
