Sword capture with 2 Kinect V2 Cameras
https://forum.ipisoft.com/viewtopic.php?f=6&t=10569
Author:  virtualdestructor [ Mon Jul 24, 2023 11:00 pm ]
Post subject:  Sword capture with 2 Kinect V2 Cameras
I purchased iPi Mocap a few years ago and have been able to successfully capture animations using my two Kinect V2 cameras. For the first time I am running into an issue.
I am trying to record a sword animation from a very specific stance (I can't use anything premade). The setup does not capture the orientation of my hand so the sword isn't positioned properly.
I read that you can use a motion controller to capture the hand orientation. So I tried using a PS Move controller. I was able to get it connected and apparently working in iPi Recorder, but it did not seem to have any effect. The angle of the sword was still wrong.
I tried using the Switch Joy-Cons, I could not get them to pair with my PC. And then I tried an old Wiimote, but ran into bluetooth issues.
What is the best way to record the correct orientation of the sword?
I was messing around trying other animations and they seemed to work fine so I think my Kinect setup is ok:
Author:  andrew [ Tue Sep 05, 2023 7:20 am ]
Post subject:  Re: Sword capture with 2 Kinect V2 Cameras
Hello virtualdestructor,
Thank you for your question and sharing this great pics. Sorry for the silly question, but did you follow this guide? There are two the most important things:
  • first, to align motion controller(s) with 3D scene orientation (in horizontal plane)
  • then, to apply motion controller(s) data to appropriate body part (right hand, in your case)
