| cameras distance from the floor https://forum.ipisoft.com/viewtopic.php?f=6&t=4158 |
| Author: | stuckon3d [ Wed Aug 18, 2010 11:18 am ] |
| Post subject: | cameras distance from the floor |
I know about having to put the 4 cams at a semi circle but do you get better mocap having all of them at the same height or at different heights? thanks in advanced, Stuckon3d |
| Author: | andrew [ Wed Aug 18, 2010 11:34 am ] |
| Post subject: | Re: cameras distance from the floor |
Hello, for correct foot and shoulder tracking it is important to have at least one camera at 2+ meters height. As to others you can fix them at about 1.5 meters height. For example see slide 7 here. Also you can follow the advises from Greenlaw: Quote: The setup I've been using lately seems to work very well for me: It's a half-circle arrangement, with the cameras about 2 to 3 meters up, and far back enough to see the full figure of the performer with plenty of space around him. I have to check, but I think the cameras are 4 meters or so from the performe
| Author: | stuckon3d [ Wed Aug 18, 2010 3:16 pm ] |
Thank you Andrew, this weekend is going to be the big test for me, im going to take my living room apart so i have some space to move around. I hope that it is enough :) |
| Author: | shoki [ Tue Feb 15, 2011 3:36 am ] |
Hi, just wondered what is the distance between the cams? im tryign to get an idea of what floorspace ill need for this, I got a room in mind (a loft conversion) but it has a white beam right in the middle! so I hope i can mound the middle cam on that and 1 either side... think it will be ok but just trying to plan this all out Thanks |
