It is currently Sun Nov 08, 2026 6:34 pm
 Post subject: 2-Camera Configuration?
PostPosted: Tue Jun 28, 2011 3:01 pm
Anyone done a 2 camera configuration? if so, how did it turn out?
PostPosted: Wed Jun 29, 2011 8:27 pm
You can try, but I would use at least 3 cameras
PostPosted: Thu Jun 30, 2011 2:56 am
My guess is that the result may be comparable to using a Kinect, meaning you must always perform to the 'front view' for best results. In which case, you should probably just use a Kinect because I imagine that with only two 2D cameras for capture, you may experience a lot of extra jittering when tracking.
Dueyftw is correct; if you're going to use the PS3 Eye, you need to use a minimum of three cameras to make it worthwhile. IMO, a minimum of four is highly recommended.
