| 2-Camera Configuration? https://forum.ipisoft.com/viewtopic.php?f=6&t=5163 |
| Author: | jay.pis [ Tue Jun 28, 2011 3:01 pm ] |
| Post subject: | 2-Camera Configuration? |
Anyone done a 2 camera configuration? if so, how did it turn out? |
| Author: | dueyftw [ Wed Jun 29, 2011 8:27 pm ] |
| Post subject: | Re: 2-Camera Configuration? |
You can try, but I would use at least 3 cameras |
| Author: | Greenlaw [ Thu Jun 30, 2011 2:56 am ] |
My guess is that the result may be comparable to using a Kinect, meaning you must always perform to the 'front view' for best results. In which case, you should probably just use a Kinect because I imagine that with only two 2D cameras for capture, you may experience a lot of extra jittering when tracking. Dueyftw is correct; if you're going to use the PS3 Eye, you need to use a minimum of three cameras to make it worthwhile. IMO, a minimum of four is highly recommended. G. |
