It is currently Mon Nov 09, 2026 12:19 am
 Post subject: Iam Newbie, Please Help.
PostPosted: Sat Nov 12, 2011 1:09 am
Dear ipiSoft DMC;
or anyone who is familiar with the ipisoft + kinect. :)
This my Specs :
Procie : Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
OS : Windows 7 32-bit
Memory : 4GB
HDD : 2TB
VGA : GeForce GTX 460
Driver : Nvidia 285.79
OpenGL : 4.2
Can I use ipisoft + kinect, if I using specifications as listed above?
and What is the most frequent and may cause a program crash?
Thanks.
PostPosted: Sat Nov 12, 2011 11:00 am
Hello :) from your description of your system, I would think that ipi would work fine for you with a kinect setup. Is your procie a dual core or a quad core? The only recommendation I would suggest is to add at least 2 more gigs to your ram if you can. Other than that your system should be fine.
Good luck!
Pat
PostPosted: Sat Nov 12, 2011 3:47 pm
The i3 processor duo core and it is perfectly fine for a single Kinect senor.
I'm not sure it can handle dual Kinect sensors though--maybe? It may depend on the number of controllers you have and how fast your capture drive is. I'm just guessing about dual Kinect for this processor so if anybody else knows for certain, please post. There's probably more info somewhere in the wiki so I would check there.
Your graphics card is perfect...it's what I use. :)
Users browsing this forum: No registered users and 38 guests
