Can't get Kinnect to show up in iPi Recorder
https://forum.ipisoft.com/viewtopic.php?f=6&t=5850
Author:  eric3020 [ Thu Feb 16, 2012 10:36 pm ]
Post subject:  Can't get Kinnect to show up in iPi Recorder
Hi!
I tried to install Ipi recorder but when I plug in my Kinnect in, ipirecorder doesn't see my kinect. :(
I know this issue was addressed in an earlier post but the answer was just to reinstall the drivers and it didn't work for me.
When I look in the Device Manager, it lists PrimeSensor, and under it, only "XboxNUIMotor". Shouldn't there be more stuff there, like "XBox NUI Camera", like it lists in the docs?
I'm using 64 bit windows 7.
Any tips that I could try??
Thanks!
Eric
Author:  andrew [ Thu Feb 16, 2012 11:07 pm ]
Post subject:  Re: Can't get Kinnect to show up in iPi Recorder
Please, try to download and install the latest version of iPiRecorder. Alter installation of it you can try to install Microsoft Kinect for Windows SDK from here: http://www.microsoft.com/en-us/kinectforwindows/develop/. It can help.
Author:  eric3020 [ Fri Feb 17, 2012 12:02 am ]
Thanks! However It's still not working.
I am using Windows 7, the latest version (1.7.0.80) of iPi recorder and I just downloaded the Microsoft Windows for Kinect SDK
I think the PC sees the Kinect because in the Device Manager it lists Microsoft Kinect, and under it Microsoft Kinect Device (When the Kinect is plugged in to the USB port)
However when I launch Ipi Recorder, The camera selector only shows my webcam.
Any clues to what is wrong?
Thanks!
Eric
Author:  andrew [ Fri Feb 17, 2012 12:08 am ]
eric3020, could you please provide us with screenshot of your device manager with expanded Microsoft Kinect item?
Author:  eric3020 [ Fri Feb 17, 2012 12:59 pm ]
Sure! Here is a screen capture of my device manager when I plug in the Kinect to the USB port. And thank you so much for the prompt responses!
- Eric
Author:  andrew [ Fri Feb 17, 2012 1:18 pm ]
Hello!
4 devices should be presented in Device Manager for one MS Kinect Sensor:
1. Microsoft Kinect Audio Array Controll
2. Microsoft Kinect Camera
3. Microsoft Kinect Device
4. Microsoft Kinect Security Controll
But you have only one (#3). It's not good.
Possible reasons:
  • you didn't plug your Kinect Sencor to AC/DC adapter (external power supply is not optional!)
  • you plugged your Kinect Sensor to PC through USB 1.x port rather than 2.0
Author:  eric3020 [ Fri Feb 17, 2012 9:19 pm ]
It was the power cord - the external power outlet wasn't plugged in.
It works fine now!!
Yes I am a moron when it comes to hardware....
But the USB tip is certainly good to know as well.
Thank you so much for your help! I will hopefully post some cool animation soon!
Eric
