| 10M Active USB Cables https://forum.ipisoft.com/viewtopic.php?f=6&t=6847 |
| Author: | Jbaum [ Thu Feb 28, 2013 7:34 am ] |
| Post subject: | 10M Active USB Cables |
We purchased the standard version, 6 SONY PS cameras, and six 10M active USB2 cables. When we set everything up, IPI is telling us that the max we can get is 320x240 @30 FPS. Naturally we thought we were going to get full frame resolution @ 30FPS. Is this normal or should I be looking at different active USB cables? |
| Author: | vmaslov [ Thu Feb 28, 2013 11:37 pm ] |
| Post subject: | Re: 10M Active USB Cables |
Jbaum wrote: When we set everything up, IPI is telling us that the max we can get is 320x240 @30 FPS. Naturally we thought we were going to get full frame resolution @ 30FPS. How the software is "telling" you about the max? When everything is setup OK, you can get 640x480@60fps with PS Eyes. Did you follow the recommendation of no more than 2 cameras on a single USB controller? |
| Author: | Jbaum [ Fri Mar 01, 2013 6:43 am ] |
That might be the problem, more than 2 cameras /controller. I'm going out today and buy a couple of USB 3.0 cards and try it again. Thanks for the suggestion/reminder. |
| Author: | Jbaum [ Tue Mar 19, 2013 9:17 am ] |
Bought two USB 3 cards, and we're now getting 640x480 @ 40FPS. Thanks. |
| Author: | plang [ Fri Mar 22, 2013 2:30 am ] |
You cannot get 60 FPS? |
| Author: | Jbaum [ Fri Mar 22, 2013 5:40 am ] |
When I jump it up to 50fps, two of the cameras drop frames. |
