FPS on Kinect
https://forum.ipisoft.com/viewtopic.php?f=6&t=6967
Author:  haricobean [ Mon Mar 18, 2013 5:40 am ]
Post subject:  FPS on Kinect
I am using iPi record to motion capture an actor that I then want add the bvh to a skeleton and then composite the 3d and the live action together.
I have tested this and am getting good results however the kinect seems to recording at 30fps and I can't seem to change it.
Can I set a frame rate to record in iPi? If not should I shoot my live ation at 30fps as well.
H
Author:  vmaslov [ Mon Mar 18, 2013 5:58 am ]
Post subject:  Re: FPS on Kinect
Kinect does not support higher frame rates.
However, you can get the same output frame rate for animation and live video later:
  • Either change the frame rate of the video using video editing software.
  • Or change the animation frame rate using the animation editing software capable of interpolating between the key frames.
Author:  haricobean [ Mon Mar 18, 2013 8:32 am ]
ok thanks. I am shooting Pal (25fps) live action so was hoping to set the kinect to 25fps instead of 30fps , so a lower frame rate. But can't find any settings to do this.
Guess will need to shoot live action at 30fps.
thanks
H
Author:  vmaslov [ Mon Mar 18, 2013 8:53 am ]
Kinect does not support 25fps.
However, many animation packages have a feature to change the output animation frame rate. For example, in 3DS Max:
http://docs.autodesk.com/3DSMAX/15/ENU/3ds-Max-Help/index.html?url=files/GUID-2F41BBF4-D9E7-4171-A369-EA45CAFAD147.htm,topicNumber=d30e216294
So you can adjust the animation after exporting from iPi Mocap Studio to desired 25fps.
