Leg Twist in the end of scene
https://forum.ipisoft.com/viewtopic.php?f=6&t=8869
Author:  eyali [ Wed Oct 30, 2013 12:59 am ]
Post subject:  Leg Twist in the end of scene
Hi All,
I new to ipisoft. I have 1 kinect for windows that I track my motions with.
I made very short animation tracking. I start with a T pose and bend over to pick something up (no props just make it like I pick something up) and lift it over my hand and return to put the it back on the floor. It all works great until the end of the scene where my left leg when bending is twisting after (tracker is twisting my actor left leg). The thing is that I bend also at the beginning and no twisting occurs. Is there a way to fix this problem like fixing IK of leg manually. I don't want to shoot the scene again :-)
Thank u in advace
Eyal
Author:  vmaslov [ Wed Oct 30, 2013 5:47 am ]
Post subject:  Re: Leg Twist in the end of scene
Please read about clean-up in our wiki:
http://wiki.ipisoft.com/Clean-up
In short, you need to manually correct the pose in incorrect frame with Rotate/IK tools, then hit Refit Pose for more accurate correction, and then track backward/forward from this corrected frame to correct other frames.
Author:  eyali [ Wed Oct 30, 2013 2:18 pm ]
Thank u for your answer. But When I repose the foot via IK and enter refitpose I ger a twisted leg for this pose...
Author:  vmaslov [ Thu Oct 31, 2013 12:14 am ]
Have you turned off trajectory filtering (decrease it to zero value) before doing Refit Pose? If not, then you must be seeing already filtered pose, which considers neighbour incorrect frames, and not the exact result of Refit Pose.
Author:  eyali [ Sun Nov 03, 2013 10:18 pm ]
I see
Thank u :-)
