PostPosted: Fri Nov 29, 2013 12:48 am
I downloaded a long time and loved the soft ipi , tested with only one kinect
Today I went back to check on the program, interested me greatly, I'm with two Kinects, but when I test version to see if it is worth my investment,
I could not use, the version had expired
formatted the pc, changed the HD but still expired
I do not know if it's because already used it once, or live in Brazil and the schedule is different
I think by the time difference of the parents, the program thinks I'm trying to falsify hours
how do I get a key 30 days so I can test 2 Kinects, and decide to buy?
Thanks, sorry errors, do not know English ... I am Brazilian and I used to translate
PostPosted: Fri Nov 29, 2013 2:23 am
Hello
This is how our license protection works - you cannot run the trial twice on the same PC. If you want another trial, you need to find another PC.
Anyway, you can do tracking with 2 Kinects and preview the animation in iPi Mocap Studio even with expired trial. The only thing you cannot do is to export an animation. However, you can send us a couple of trial project files with complete tracking, and we will export the animation for you, so you can also test the pipeline with animation software.
PostPosted: Fri Nov 29, 2013 5:31 am
but I am in doubt, if I buy a new computer, will give error? because the Brazilian clock be different? I am in doubt
are now 10:30 AM
PostPosted: Fri Nov 29, 2013 8:04 am
Our license protection is tolerant to automatic shifts of time caused by time zone changes. So do not worry about that.
PostPosted: Sat Nov 30, 2013 8:30 am
are now 10:30 AM
This is only an opinion but I wouldn't purchase a new computer just to test iPi Mocap Studio--as mentioned, you should be a able to use your expired trial version with 2 Kinects, you just can't export the tracked data. If you really need the tracked data to validate your purchasing decision, I would take iPi Soft's offer to output the test data for you. That's certainly a more cost effective option.
Now, if your second Kinect doesn't show up on your current computer, that's a different situation. There may be an hardware limitation with your computer, which may not involve the limitations of the trial version of Mocap Studio. It probably has to do with your USB controllers but without more information, it's hard to know for sure.
