| can't launch ipi https://forum.ipisoft.com/viewtopic.php?f=6&t=8942 |
Page 1 of 2 |
| Author: | steffjm [ Sun Jan 19, 2014 8:42 am ] |
| Post subject: | can't launch ipi |
I install trial version ipi but program can't be launched here install.log The following properties have been set: Property: [AdminUser] = true {boolean} Property: [ProcessorArchitecture] = AMD64 {string} Property: [VersionNT] = 6.1.1 {version} Running checks for package 'Windows Installer 3.1', phase BuildList The following properties have been set for package 'Windows Installer 3.1': Running checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.1': true Result of checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' is 'Bypass' 'Windows Installer 3.1' RunCheck result: No Install Needed Running checks for package '.NET Framework 3.5 SP1', phase BuildList Reading value 'SP' of registry key 'HKLM\Software\Microsoft\NET Framework Setup\NDP\v3.5' Read integer value 1 Setting value '1 {int}' for property 'DotNet35SP' The following properties have been set for package '.NET Framework 3.5 SP1': Property: [DotNet35SP] = 1 {int} Running checks for command 'DotNetFX35SP1\dotNetFx35setup.exe' Result of running operator 'ValueGreaterThanEqualTo' on property 'DotNet35SP' and value '1': true Result of checks for command 'DotNetFX35SP1\dotNetFx35setup.exe' is 'Bypass' '.NET Framework 3.5 SP1' RunCheck result: No Install Needed Running checks for package 'Microsoft XNA Framework Redistributable 3.0', phase BuildList Reading value 'ProductVersion' of registry key 'HKLM\Software\Microsoft\XNA\Framework\v3.0' Read string value '3.0.11010.0' Setting value '3.0.11010.0 {string}' for property 'XNAFX30_IS_INSTALLED' The following properties have been set for package 'Microsoft XNA Framework Redistributable 3.0': Property: [XNAFX30_IS_INSTALLED] = 3.0.11010.0 {string} Running checks for command 'XnaFxRedist30\xnafx30_redist.msi' Result of running operator 'ValueEqualTo' on property 'XNAFX30_IS_INSTALLED' and value '3.0.11010.0': true Result of checks for command 'XnaFxRedist30\xnafx30_redist.msi' is 'Bypass' 'Microsoft XNA Framework Redistributable 3.0' RunCheck result: No Install Needed Launching Application. Application appears to be an application manifest Launching application manifest via dfshim LaunchApplication failed with HRESULT '-2147221164' Running command 'C:\Users\VISTAJ~1\AppData\Local\Temp\{3BE43D2B-40E7-4BB2-B39B-22D44A74A9C8}\s\iPiMocapStudio.application' with arguments '' Is my pC compatible ? |
| Author: | vmaslov [ Mon Jan 20, 2014 2:31 am ] |
| Post subject: | Re: can't launch ipi |
Do you have a shortcut for iPi Mocap Studio installed? If so, run the shortcut and see whether you can get any error details from the crash message box. |
| Author: | steffjm [ Mon Jan 20, 2014 9:27 am ] |
Sorry, Therese IS any short cut of the program. No new folder in program 64 or program(x86) folder I tried many Time to install. After install nothing append. Program is not listed in applications in control panel. Nothing |
| Author: | vmaslov [ Mon Jan 20, 2014 1:45 pm ] |
What version of iPi Mocap Studio do you install? Is this the latest release downloaded from our website? http://files.ipisoft.com/iPiMocapStudioSetup.exe |
| Author: | steffjm [ Mon Jan 20, 2014 3:53 pm ] |
yes it is |
| Author: | steffjm [ Mon Jan 20, 2014 8:56 pm ] |
I do install again but alway no shortcut and no error message. I found this file in localdata iPiMocapStudio2InstallLog.txt 2014-01-20 22:49:52 ------------------------------------------------------------------- 2014-01-20 22:49:52 dotNetInstaller (DNI), version 2.2.718.0 2014-01-20 22:49:52 Copyright (c) DevAge, Vestris Inc. & Contributors 2014-01-20 22:49:52 Operating system: Windows 7 SP1 (x64) 2014-01-20 22:49:52 ------------------------------------------------------------------- 2014-01-20 22:49:52 Sequence: install 2014-01-20 22:49:52 UI level: full 2014-01-20 22:49:52 Configuration language id: 1033 2014-01-20 22:49:52 -- Loading supported components (lcid=1033) 2014-01-20 22:49:52 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:49:52 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:49:52 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:49:52 -- iPi Mocap Studio 2.5.1.159 (display_name='iPi Mocap Studio 2.5.1.159', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:49:52 --- Loaded 4 supported component(s) 2014-01-20 22:49:52 Checking whether registry value 'SOFTWARE\Microsoft\DirectX\Version' exists 2014-01-20 22:49:52 Registry value: 4.09.00.0904 2014-01-20 22:49:52 -- DirectX End-User Runtimes 9.0c (DirectX End-User Runtimes 9.0c): INSTALLED 2014-01-20 22:49:52 Checking whether registry value 'Software\Microsoft\NET Framework Setup\NDP\v3.5\Install' exists 2014-01-20 22:49:52 Registry value: 1 2014-01-20 22:49:52 Check value: 1 2014-01-20 22:49:52 -- Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1): INSTALLED 2014-01-20 22:49:52 Checking whether registry value 'Software\Microsoft\XNA\Framework\v3.0\ProductVersion' exists 2014-01-20 22:49:52 Registry value: 3.0.11010.0 2014-01-20 22:49:52 -- Microsoft XNA Framework Redistributable 3.0 (Microsoft XNA Framework Redistributable 3.0): INSTALLED 2014-01-20 22:49:52 Checking file: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\iPiMocapStudio.application 2014-01-20 22:49:52 -- iPi Mocap Studio 2.5.1.159 (iPi Mocap Studio 2.5.1.159): NOT INSTALLED 2014-01-20 22:49:52 All required components installed: no 2014-01-20 22:49:52 All optional components installed: yes 2014-01-20 22:49:52 -- Adding 'license' control, text='I have read and accepted the license agreement', font=MS Shell Dlg (10 pt.), left=15, top=315, width=400, height=25 2014-01-20 22:49:52 Extracting license 'RES_LICENSE' to C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}_EULA.html 2014-01-20 22:49:52 -- Adding 'label' control, text='The following components should be installed to run iPi Mocap Studio:', font=MS Shell Dlg (11 pt.), left=15, top=95, width=590, height=20 2014-01-20 22:49:52 -- Adding 'label' control, text='(Note that for the installation of Microsoft .NET Framework 3.5 SP1 internet connection is required.)', font=MS Shell Dlg (9 pt.), left=15, top=115, width=590, height=20 2014-01-20 22:49:52 -- Adding 'label' control, text='For more information about iPi Mocap Studio installation please visit the following link:', font=MS Shell Dlg (9 pt.), left=15, top=355, width=590, height=20 2014-01-20 22:49:52 -- Adding 'hyperlink' control, uri=http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation, text='http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation', font=MS Shell Dlg (9 pt.), left=15, top=370, width=590, height=20 2014-01-20 22:49:52 Start: install 2014-01-20 22:49:59 -- Loading supported components (lcid=1033) 2014-01-20 22:49:59 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:49:59 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:49:59 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:49:59 -- iPi Mocap Studio 2.5.1.159 (display_name='iPi Mocap Studio 2.5.1.159', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:49:59 --- Loaded 4 supported component(s) 2014-01-20 22:49:59 *** Failed to install one or more components: Please accept license agreement in order to install iPi Mocap Studio. 2014-01-20 22:50:03 -- Loading supported components (lcid=1033) 2014-01-20 22:50:03 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:50:03 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:50:03 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:50:03 -- iPi Mocap Studio 2.5.1.159 (display_name='iPi Mocap Studio 2.5.1.159', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:50:03 --- Loaded 4 supported component(s) 2014-01-20 22:50:03 --- Setting user-defined value 'RES_LICENSE'=1 2014-01-20 22:50:03 Extracting embedded files for component '*': NO FILES EMBEDDED 2014-01-20 22:50:03 --- Component 'DirectX End-User Runtimes 9.0c' (DirectX End-User Runtimes 9.0c): SKIPPED 2014-01-20 22:50:03 --- Component 'Microsoft .NET Framework 3.5 SP1' (Microsoft .NET Framework 3.5 SP1): SKIPPED 2014-01-20 22:50:03 --- Component 'Microsoft XNA Framework Redistributable 3.0' (Microsoft XNA Framework Redistributable 3.0): SKIPPED 2014-01-20 22:50:03 --- Component 'iPi Mocap Studio 2.5.1.159' (iPi Mocap Studio 2.5.1.159): EXECUTING 2014-01-20 22:50:03 Extracting embedded files for component 'iPi Mocap Studio 2.5.1.159': 1 CAB(s) 2014-01-20 22:50:03 Resolved CAB path 'C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}' for component 'IPI_MOCAP_STUDIO_2_5_1_159' 2014-01-20 22:50:03 Extracting 'SETUP_IPI_MOCAP_STUDIO_2_5_1_159_1.CAB' for component 'IPI_MOCAP_STUDIO_2_5_1_159' 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\iPiMocapStudio.application 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\iPiMocapStudio.application 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\setup.exe 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\setup.exe 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\EULA.html.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\EULA.html.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiDepthSensorCalibration.dll.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiDepthSensorCalibration.dll.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiHelpers.dll.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiHelpers.dll.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiLib.Fbx.dll.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiLib.Fbx.dll.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMath.dll.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMath.dll.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.config.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.config.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.manifest 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.manifest 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiVideo.dll.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiVideo.dll.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiVideo.WpfTools.dll.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiVideo.WpfTools.dll.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\NAudio.dll.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\NAudio.dll.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\OxyPlot.dll.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\OxyPlot.dll.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\OxyPlot.Wpf.dll.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\OxyPlot.Wpf.dll.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\SharpAvi.dll.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\SharpAvi.dll.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\TaskDialog.dll.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\TaskDialog.dll.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\actor.ico.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\actor.ico.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\batch.ico.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\batch.ico.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\iPiStudio.ico.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\iPiStudio.ico.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\MoCapProj.ico.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\MoCapProj.ico.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\MoCapTrialProj.ico.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\MoCapTrialProj.ico.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Keyboard Shortcuts.xps.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Keyboard Shortcuts.xps.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Release Notes.xps.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Release Notes.xps.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Dual Depth Sensor Configuration.xps.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Dual Depth Sensor Configuration.xps.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Multiple PS Eye Cameras Configuration.xps.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Multiple PS Eye Cameras Configuration.xps.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Single Depth Sensor Configuration.xps.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Single Depth Sensor Configuration.xps.deploy 2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Welcome.xps.deploy 2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Welcome.xps.deploy 2014-01-20 22:50:04 -- Executable: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\setup.exe 2014-01-20 22:50:04 Executing: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\setup.exe 2014-01-20 22:50:20 --- Component 'iPi Mocap Studio 2.5.1.159 (iPi Mocap Studio 2.5.1.159): DIALOG CLOSED 2014-01-20 22:50:20 *** Component 'iPi Mocap Studio 2.5.1.159' (iPi Mocap Studio 2.5.1.159): SUCCESS 2014-01-20 22:50:20 -- Loading supported components (lcid=1033) 2014-01-20 22:50:20 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:50:20 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:50:20 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:50:20 -- iPi Mocap Studio 2.5.1.159 (display_name='iPi Mocap Studio 2.5.1.159', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED 2014-01-20 22:50:20 --- Loaded 4 supported component(s) 2014-01-20 22:50:20 Checking whether registry value 'SOFTWARE\Microsoft\DirectX\Version' exists 2014-01-20 22:50:20 Registry value: 4.09.00.0904 2014-01-20 22:50:20 -- DirectX End-User Runtimes 9.0c (DirectX End-User Runtimes 9.0c): INSTALLED 2014-01-20 22:50:20 Checking whether registry value 'Software\Microsoft\NET Framework Setup\NDP\v3.5\Install' exists 2014-01-20 22:50:20 Registry value: 1 2014-01-20 22:50:20 Check value: 1 2014-01-20 22:50:20 -- Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1): INSTALLED 2014-01-20 22:50:20 Checking whether registry value 'Software\Microsoft\XNA\Framework\v3.0\ProductVersion' exists 2014-01-20 22:50:20 Registry value: 3.0.11010.0 2014-01-20 22:50:20 -- Microsoft XNA Framework Redistributable 3.0 (Microsoft XNA Framework Redistributable 3.0): INSTALLED 2014-01-20 22:50:20 Checking file: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\iPiMocapStudio.application 2014-01-20 22:50:20 -- iPi Mocap Studio 2.5.1.159 (iPi Mocap Studio 2.5.1.159): INSTALLED 2014-01-20 22:50:20 All required components installed: yes 2014-01-20 22:50:20 All optional components installed: yes 2014-01-20 22:50:20 --- Complete Command 2014-01-20 22:50:20 Deleting 'C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}_EULA.html' 2014-01-20 22:50:20 dotNetInstaller finished, return code: 0 (0x0) |
| Author: | vmaslov [ Tue Jan 21, 2014 1:46 am ] |
The installer log reports about successful installation. That's weird. Please try the alternative MSI installer: http://files.ipisoft.com/iPiMocapStudio.msi |
| Author: | steffjm [ Tue Jan 21, 2014 7:46 pm ] |
install is ok now but, Crash on launch... I think my hardware maybe incompatible. thank's for your help. I will waiting for my new computer |
| Author: | vmaslov [ Wed Jan 22, 2014 2:50 am ] |
Any detailed info about the crash? Regarding compatibility - what's your video card? Other components do not matter much for Mocap Studio. |
| Author: | steffjm [ Wed Jan 22, 2014 7:39 am ] |
This some captures simple error windows say, program stop before started non screen of program ipisoft Attachment: CaptureCPU.PNG [ 15.27 KiB | Viewed 26728 times ] Attachment: CaptureGPU.PNG [ 57.41 KiB | Viewed 26728 times ] |
| Page 1 of 2 | All times are UTC - 8 hours [ DST ] |
