It is currently Sun Nov 08, 2026 4:20 pm
Post a new topicPost a reply Page 1 of 2   [ 17 posts ]
 Post subject: can't launch ipi
PostPosted: Sun Jan 19, 2014 8:42 am
I install trial version ipi but program can't be launched
here install.log
The following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [ProcessorArchitecture] = AMD64 {string}
Property: [VersionNT] = 6.1.1 {version}
Running checks for package 'Windows Installer 3.1', phase BuildList
The following properties have been set for package 'Windows Installer 3.1':
Running checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe'
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.1': true
Result of checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' is 'Bypass'
'Windows Installer 3.1' RunCheck result: No Install Needed
Running checks for package '.NET Framework 3.5 SP1', phase BuildList
Reading value 'SP' of registry key 'HKLM\Software\Microsoft\NET Framework Setup\NDP\v3.5'
Read integer value 1
Setting value '1 {int}' for property 'DotNet35SP'
The following properties have been set for package '.NET Framework 3.5 SP1':
Property: [DotNet35SP] = 1 {int}
Running checks for command 'DotNetFX35SP1\dotNetFx35setup.exe'
Result of running operator 'ValueGreaterThanEqualTo' on property 'DotNet35SP' and value '1': true
Result of checks for command 'DotNetFX35SP1\dotNetFx35setup.exe' is 'Bypass'
'.NET Framework 3.5 SP1' RunCheck result: No Install Needed
Running checks for package 'Microsoft XNA Framework Redistributable 3.0', phase BuildList
Reading value 'ProductVersion' of registry key 'HKLM\Software\Microsoft\XNA\Framework\v3.0'
Read string value '3.0.11010.0'
Setting value '3.0.11010.0 {string}' for property 'XNAFX30_IS_INSTALLED'
The following properties have been set for package 'Microsoft XNA Framework Redistributable 3.0':
Property: [XNAFX30_IS_INSTALLED] = 3.0.11010.0 {string}
Running checks for command 'XnaFxRedist30\xnafx30_redist.msi'
Result of running operator 'ValueEqualTo' on property 'XNAFX30_IS_INSTALLED' and value '3.0.11010.0': true
Result of checks for command 'XnaFxRedist30\xnafx30_redist.msi' is 'Bypass'
'Microsoft XNA Framework Redistributable 3.0' RunCheck result: No Install Needed
Launching Application.
Application appears to be an application manifest
Launching application manifest via dfshim
LaunchApplication failed with HRESULT '-2147221164'
Running command 'C:\Users\VISTAJ~1\AppData\Local\Temp\{3BE43D2B-40E7-4BB2-B39B-22D44A74A9C8}\s\iPiMocapStudio.application' with arguments ''
Is my pC compatible ?
 Post subject: Re: can't launch ipi
PostPosted: Mon Jan 20, 2014 2:31 am
Do you have a shortcut for iPi Mocap Studio installed? If so, run the shortcut and see whether you can get any error details from the crash message box.
PostPosted: Mon Jan 20, 2014 9:27 am
Sorry, Therese IS any short cut of the program.
No new folder in program 64 or program(x86) folder
I tried many Time to install.
After install nothing append.
Program is not listed in applications in control panel. Nothing
PostPosted: Mon Jan 20, 2014 1:45 pm
What version of iPi Mocap Studio do you install? Is this the latest release downloaded from our website?
http://files.ipisoft.com/iPiMocapStudioSetup.exe
PostPosted: Mon Jan 20, 2014 3:53 pm
yes it is
PostPosted: Mon Jan 20, 2014 8:56 pm
I do install again but alway no shortcut and no error message.
I found this file in localdata
iPiMocapStudio2InstallLog.txt
2014-01-20 22:49:52 -------------------------------------------------------------------
2014-01-20 22:49:52 dotNetInstaller (DNI), version 2.2.718.0
2014-01-20 22:49:52 Copyright (c) DevAge, Vestris Inc. & Contributors
2014-01-20 22:49:52 Operating system: Windows 7 SP1 (x64)
2014-01-20 22:49:52 Sequence: install
2014-01-20 22:49:52 UI level: full
2014-01-20 22:49:52 Configuration language id: 1033
2014-01-20 22:49:52 -- Loading supported components (lcid=1033)
2014-01-20 22:49:52 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:49:52 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:49:52 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:49:52 -- iPi Mocap Studio 2.5.1.159 (display_name='iPi Mocap Studio 2.5.1.159', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:49:52 --- Loaded 4 supported component(s)
2014-01-20 22:49:52 Checking whether registry value 'SOFTWARE\Microsoft\DirectX\Version' exists
2014-01-20 22:49:52 Registry value: 4.09.00.0904
2014-01-20 22:49:52 -- DirectX End-User Runtimes 9.0c (DirectX End-User Runtimes 9.0c): INSTALLED
2014-01-20 22:49:52 Checking whether registry value 'Software\Microsoft\NET Framework Setup\NDP\v3.5\Install' exists
2014-01-20 22:49:52 Registry value: 1
2014-01-20 22:49:52 Check value: 1
2014-01-20 22:49:52 -- Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1): INSTALLED
2014-01-20 22:49:52 Checking whether registry value 'Software\Microsoft\XNA\Framework\v3.0\ProductVersion' exists
2014-01-20 22:49:52 Registry value: 3.0.11010.0
2014-01-20 22:49:52 -- Microsoft XNA Framework Redistributable 3.0 (Microsoft XNA Framework Redistributable 3.0): INSTALLED
2014-01-20 22:49:52 Checking file: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\iPiMocapStudio.application
2014-01-20 22:49:52 -- iPi Mocap Studio 2.5.1.159 (iPi Mocap Studio 2.5.1.159): NOT INSTALLED
2014-01-20 22:49:52 All required components installed: no
2014-01-20 22:49:52 All optional components installed: yes
2014-01-20 22:49:52 -- Adding 'license' control, text='I have read and accepted the license agreement', font=MS Shell Dlg (10 pt.), left=15, top=315, width=400, height=25
2014-01-20 22:49:52 Extracting license 'RES_LICENSE' to C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}_EULA.html
2014-01-20 22:49:52 -- Adding 'label' control, text='The following components should be installed to run iPi Mocap Studio:', font=MS Shell Dlg (11 pt.), left=15, top=95, width=590, height=20
2014-01-20 22:49:52 -- Adding 'label' control, text='(Note that for the installation of Microsoft .NET Framework 3.5 SP1 internet connection is required.)', font=MS Shell Dlg (9 pt.), left=15, top=115, width=590, height=20
2014-01-20 22:49:52 -- Adding 'label' control, text='For more information about iPi Mocap Studio installation please visit the following link:', font=MS Shell Dlg (9 pt.), left=15, top=355, width=590, height=20
2014-01-20 22:49:52 -- Adding 'hyperlink' control, uri=http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation, text='http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation', font=MS Shell Dlg (9 pt.), left=15, top=370, width=590, height=20
2014-01-20 22:49:52 Start: install
2014-01-20 22:49:59 -- Loading supported components (lcid=1033)
2014-01-20 22:49:59 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:49:59 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:49:59 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:49:59 -- iPi Mocap Studio 2.5.1.159 (display_name='iPi Mocap Studio 2.5.1.159', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:49:59 --- Loaded 4 supported component(s)
2014-01-20 22:49:59 *** Failed to install one or more components: Please accept license agreement in order to install iPi Mocap Studio.
2014-01-20 22:50:03 -- Loading supported components (lcid=1033)
2014-01-20 22:50:03 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:50:03 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:50:03 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:50:03 -- iPi Mocap Studio 2.5.1.159 (display_name='iPi Mocap Studio 2.5.1.159', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:50:03 --- Loaded 4 supported component(s)
2014-01-20 22:50:03 --- Setting user-defined value 'RES_LICENSE'=1
2014-01-20 22:50:03 Extracting embedded files for component '*': NO FILES EMBEDDED
2014-01-20 22:50:03 --- Component 'DirectX End-User Runtimes 9.0c' (DirectX End-User Runtimes 9.0c): SKIPPED
2014-01-20 22:50:03 --- Component 'Microsoft .NET Framework 3.5 SP1' (Microsoft .NET Framework 3.5 SP1): SKIPPED
2014-01-20 22:50:03 --- Component 'Microsoft XNA Framework Redistributable 3.0' (Microsoft XNA Framework Redistributable 3.0): SKIPPED
2014-01-20 22:50:03 --- Component 'iPi Mocap Studio 2.5.1.159' (iPi Mocap Studio 2.5.1.159): EXECUTING
2014-01-20 22:50:03 Extracting embedded files for component 'iPi Mocap Studio 2.5.1.159': 1 CAB(s)
2014-01-20 22:50:03 Resolved CAB path 'C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}' for component 'IPI_MOCAP_STUDIO_2_5_1_159'
2014-01-20 22:50:03 Extracting 'SETUP_IPI_MOCAP_STUDIO_2_5_1_159_1.CAB' for component 'IPI_MOCAP_STUDIO_2_5_1_159'
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\iPiMocapStudio.application
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\iPiMocapStudio.application
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\setup.exe
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\setup.exe
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\EULA.html.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\EULA.html.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiDepthSensorCalibration.dll.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiDepthSensorCalibration.dll.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiHelpers.dll.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiHelpers.dll.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiLib.Fbx.dll.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiLib.Fbx.dll.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMath.dll.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMath.dll.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.config.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.config.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.manifest
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiMocapStudio.exe.manifest
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiVideo.dll.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiVideo.dll.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiVideo.WpfTools.dll.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\iPiVideo.WpfTools.dll.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\NAudio.dll.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\NAudio.dll.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\OxyPlot.dll.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\OxyPlot.dll.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\OxyPlot.Wpf.dll.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\OxyPlot.Wpf.dll.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\SharpAvi.dll.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\SharpAvi.dll.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\TaskDialog.dll.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\TaskDialog.dll.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\actor.ico.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\actor.ico.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\batch.ico.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\batch.ico.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\iPiStudio.ico.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\iPiStudio.ico.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\MoCapProj.ico.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\MoCapProj.ico.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\MoCapTrialProj.ico.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Resources\MoCapTrialProj.ico.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Keyboard Shortcuts.xps.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Keyboard Shortcuts.xps.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Release Notes.xps.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Release Notes.xps.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Dual Depth Sensor Configuration.xps.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Dual Depth Sensor Configuration.xps.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Multiple PS Eye Cameras Configuration.xps.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Multiple PS Eye Cameras Configuration.xps.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Single Depth Sensor Configuration.xps.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\User Guide for Single Depth Sensor Configuration.xps.deploy
2014-01-20 22:50:03 Extracting: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Welcome.xps.deploy
2014-01-20 22:50:03 Done: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\Application Files\iPiMocapStudio_2_5_1_159\Help\Welcome.xps.deploy
2014-01-20 22:50:04 -- Executable: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\setup.exe
2014-01-20 22:50:04 Executing: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\setup.exe
2014-01-20 22:50:20 --- Component 'iPi Mocap Studio 2.5.1.159 (iPi Mocap Studio 2.5.1.159): DIALOG CLOSED
2014-01-20 22:50:20 *** Component 'iPi Mocap Studio 2.5.1.159' (iPi Mocap Studio 2.5.1.159): SUCCESS
2014-01-20 22:50:20 -- Loading supported components (lcid=1033)
2014-01-20 22:50:20 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:50:20 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:50:20 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:50:20 -- iPi Mocap Studio 2.5.1.159 (display_name='iPi Mocap Studio 2.5.1.159', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2014-01-20 22:50:20 --- Loaded 4 supported component(s)
2014-01-20 22:50:20 Checking whether registry value 'SOFTWARE\Microsoft\DirectX\Version' exists
2014-01-20 22:50:20 Registry value: 4.09.00.0904
2014-01-20 22:50:20 -- DirectX End-User Runtimes 9.0c (DirectX End-User Runtimes 9.0c): INSTALLED
2014-01-20 22:50:20 Checking whether registry value 'Software\Microsoft\NET Framework Setup\NDP\v3.5\Install' exists
2014-01-20 22:50:20 Registry value: 1
2014-01-20 22:50:20 Check value: 1
2014-01-20 22:50:20 -- Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1): INSTALLED
2014-01-20 22:50:20 Checking whether registry value 'Software\Microsoft\XNA\Framework\v3.0\ProductVersion' exists
2014-01-20 22:50:20 Registry value: 3.0.11010.0
2014-01-20 22:50:20 -- Microsoft XNA Framework Redistributable 3.0 (Microsoft XNA Framework Redistributable 3.0): INSTALLED
2014-01-20 22:50:20 Checking file: C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}\s\iPiMocapStudio.application
2014-01-20 22:50:20 -- iPi Mocap Studio 2.5.1.159 (iPi Mocap Studio 2.5.1.159): INSTALLED
2014-01-20 22:50:20 All required components installed: yes
2014-01-20 22:50:20 All optional components installed: yes
2014-01-20 22:50:20 --- Complete Command
2014-01-20 22:50:20 Deleting 'C:\Users\VISTAJ~1\AppData\Local\Temp\{290CBD75-184F-47B4-A524-5CDE3B202659}_EULA.html'
2014-01-20 22:50:20 dotNetInstaller finished, return code: 0 (0x0)
PostPosted: Tue Jan 21, 2014 1:46 am
The installer log reports about successful installation. That's weird.
Please try the alternative MSI installer:
http://files.ipisoft.com/iPiMocapStudio.msi
PostPosted: Tue Jan 21, 2014 7:46 pm
install is ok now but,
Crash on launch... I think my hardware maybe incompatible.
thank's for your help. I will waiting for my new computer
PostPosted: Wed Jan 22, 2014 2:50 am
Any detailed info about the crash?
Regarding compatibility - what's your video card? Other components do not matter much for Mocap Studio.
PostPosted: Wed Jan 22, 2014 7:39 am
This some captures
simple error windows say, program stop before started
non screen of program ipisoft
Users browsing this forum: No registered users and 61 guests
