It is currently Sun Nov 08, 2026 10:43 pm
 Post subject: Ps move pairing issue
PostPosted: Tue Aug 26, 2014 7:11 am
Hi guys
Pairing issue
i'm haveing some trouble pairing my ps move controllers to the pc. i'm useing a bluesolei bluetooth dongle on windows 7. the bluetooth won't find them.
when useing the add new > ps move option on the ipi recorder it simply says seeking bluetooth with a messege below (paraphrasing here) please ensure your bluetooth is on (it is) if you are useing macintosh etc it may not show here please use the bluetooths settings to pair the controller. so im assumeing that my dongle is not compatible with ipi. as i have followed the other instructions to the letter
has anyone got a solution to this preferably a cheap one. cant say im doing great on funds at the moment
thank you
PostPosted: Sat Aug 30, 2014 8:09 am
Hello
iPi Recorder does not support the Bluesoleil BT drivers.
Get any BT dongle (supporting BT 2.0 EDR with range 10/100m) that works using standard Microsoft BT drivers. For example, ASUS USB-BT211 or TRENDnet TBW-106UB.
