It is currently Mon Nov 09, 2026 12:18 am
PostPosted: Tue Dec 16, 2014 9:44 pm
I have a problem (have been having) for a while with trying to get my rig's bone structure to work properly for Ipi, I need to figure out how i can solve this,if possible?
I use Cinema 4D.
Now I havent had this problem in the past, but after making a new rig for mocap, I ran into a problem to where all the mocap data works fine,except the fact that the data for movement, isnt really there (or it is in the wrong place).
When I say for movement, I mean that all actions look like they are done in place. If I walk to the side,my character will show the actions of walking to the side, but only standing in place,if that makes any sense.
Below I show my bone layout as the visual (Ignore the right arm bone, it wont show for some reason)
This below is the layout on paper
Now i usually export my simplified rig ( a few meshes for the body parts, and the bones as a 2014 fbx file for Ipi studio)
This is what that looks like
So then I usually get up to here before my rig seems to enlarge itself,and I presume this means something is wrong? :K
So as you can see, Notice that "Left Leg" and "Left Arm" are unfilled yet....This is because when I do use their corresponding bones, this happens:
Actually, it seems the problem only lies with "Left Arm".
^ Added in Left Leg, nothing happens
^ add in Left Arm, and this happens
Any idea how I can fix this?
Thanks.
PostPosted: Wed Dec 17, 2014 2:45 am
To get the movement right, you should map iPi root bone ('Hips') to your rig's root bone ('Bones').
Regarding the scaling issue I do not have any ideas at the first sight. You may provide the FBX file you're importing to Mocap Studio for us to test.
PostPosted: Wed Dec 17, 2014 2:49 am
I just noticed a few weird irregularities in my rig, fixing now and Ill see if that solves anything. In the meantime, the FBX is provided below.
TagsV8-Simplifed.rar [55.48 KiB]
Downloaded 1044 times
Users browsing this forum: No registered users and 34 guests
