MoCap Data is not going on my rig right?!
https://forum.ipisoft.com/viewtopic.php?f=6&t=9241
Author:  tag654 [ Tue Dec 16, 2014 9:44 pm ]
Post subject:  MoCap Data is not going on my rig right?!
I have a problem (have been having) for a while with trying to get my rig's bone structure to work properly for Ipi, I need to figure out how i can solve this,if possible?
I use Cinema 4D.
Now I havent had this problem in the past, but after making a new rig for mocap, I ran into a problem to where all the mocap data works fine,except the fact that the data for movement, isnt really there (or it is in the wrong place).
When I say for movement, I mean that all actions look like they are done in place. If I walk to the side,my character will show the actions of walking to the side, but only standing in place,if that makes any sense.
Below I show my bone layout as the visual (Ignore the right arm bone, it wont show for some reason)
This below is the layout on paper
Now i usually export my simplified rig ( a few meshes for the body parts, and the bones as a 2014 fbx file for Ipi studio)
This is what that looks like
So then I usually get up to here before my rig seems to enlarge itself,and I presume this means something is wrong? :K
So as you can see, Notice that "Left Leg" and "Left Arm" are unfilled yet....This is because when I do use their corresponding bones, this happens:
Actually, it seems the problem only lies with "Left Arm".
^ Added in Left Leg, nothing happens
^ add in Left Arm, and this happens
Any idea how I can fix this?
Thanks.
Author:  vmaslov [ Wed Dec 17, 2014 2:45 am ]
Post subject:  Re: MoCap Data is not going on my rig right?!
To get the movement right, you should map iPi root bone ('Hips') to your rig's root bone ('Bones').
Regarding the scaling issue I do not have any ideas at the first sight. You may provide the FBX file you're importing to Mocap Studio for us to test.
Author:  tag654 [ Wed Dec 17, 2014 2:49 am ]
I just noticed a few weird irregularities in my rig, fixing now and Ill see if that solves anything. In the meantime, the FBX is provided below.
TagsV8-Simplifed.rar [55.48 KiB]
Downloaded 1044 times
