| Anyone using Kinect V2 on W10 on Imac Retina 5K end 2015? https://forum.ipisoft.com/viewtopic.php?f=6&t=9901 |
Page 1 of 1 |
| Author: | Gerardo [ Fri Feb 02, 2018 3:49 pm ] |
| Post subject: | Anyone using Kinect V2 on W10 on Imac Retina 5K end 2015? |
Hi I´m trying to use a Kinect v2 in Windows on an iMac but can´t even get it to recognized, the LED doesn´t even turn on (the Green LED does turn on in Mac OS X) Any clue? Information: Kinect Configuration Verifier USB Controller: "Unknown USB 3.0 port detected. Your USB configuration may support Kinect for Windows" Kinect Connected "No Kinect for Windows v2 sensor detected" Kinect Studio Doesn´t show anything The computer is an iMac 17,1 "Core i7" 4.0 27-Inch Aluminum (Retina 5K, Late 2015/Skylake) with four USB 3.0 ports https://everymac.com/systems/apple/imac ... specs.html The Device Manager shows (transating from spanish): In the Universal Serial Bus Part: Root USB hub (USB 3.0): Microsoft controller 10.0.16299.64 (24/10/2017) C:\WINDOWS\system32\DRIVERS\USBHUB3.SYS USB generic hub USB generic hub Intel(R) USB 3.0 - 1.0 eXtensible host controller (Microsoft) Bus PCI 0, device 20, function 0 Microsoft controller 10.0.16299.125 (07/12/2017) C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS Composed USB device Composed USB device Controlador de host eXtensible Intel(R) USB 3.0 - 1.0 (Microsoft) In the Other Devices Part: (Yellow warning size) Unknown Device (Yellow warning size) Xbox NUI Engine Thanks |
| Author: | Gerardo [ Fri Feb 02, 2018 4:10 pm ] |
| Post subject: | Anyone using Kinect on W10 on Imac Retina 5K end 2015? |
Hi I´m trying to use a Kinect v2 in Windows on an iMac but can´t even get it to recognized, the LED doesn´t even turn on (the Green LED does turn on in Mac OS X) Any clue? Information: Kinect Configuration Verifier USB Controller: "Unknown USB 3.0 port detected. Your USB configuration may support Kinect for Windows" Kinect Connected "No Kinect for Windows v2 sensor detected" Kinect Studio Doesn´t show anything The computer is an iMac 17,1 "Core i7" 4.0 27-Inch Aluminum (Retina 5K, Late 2015/Skylake) with four USB 3.0 ports https://everymac.com/systems/apple/imac ... specs.html The Device Manager shows (transating from spanish): In the Universal Serial Bus Part: Root USB hub (USB 3.0): Microsoft controller 10.0.16299.64 (24/10/2017) C:\WINDOWS\system32\DRIVERS\USBHUB3.SYS USB generic hub USB generic hub Intel(R) USB 3.0 - 1.0 eXtensible host controller (Microsoft) Bus PCI 0, device 20, function 0 Microsoft controller 10.0.16299.125 (07/12/2017) C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS Composed USB device Composed USB device Controlador de host eXtensible Intel(R) USB 3.0 - 1.0 (Microsoft) In the Other Devices Part: (Yellow warning size) Unknown Device (Yellow warning size) Xbox NUI Engine Aditionally, under Mac OS X, I get this information about the USB hardware: Hub: ID del producto: 0x005a ID del fabricante: 0x0409 (NEC Corporation) Versión: 1.00 Velocidad: Hasta 480 Mb/s ID de la ubicación: 0x14300000 / 3 Corriente disponible (mA): 500 Corriente necesaria (mA): 100 Corriente operativa adicional (mA): 0 Xbox NUI Camera: ID del producto: 0x02ae ID del fabricante: 0x045e (Microsoft Corporation) Versión: 1.0b Número de serie: A00366A16506046A Velocidad: Hasta 480 Mb/s Fabricante: Microsoft ID de la ubicación: 0x14330000 / 10 Corriente disponible (mA): 500 Corriente necesaria (mA): 16 Corriente operativa adicional (mA): 0 Xbox NUI Motor: ID del producto: 0x02b0 ID del fabricante: 0x045e (Microsoft Corporation) Versión: 1.07 Velocidad: Hasta 12 Mb/s Fabricante: Microsoft ID de la ubicación: 0x14320000 / 6 Corriente disponible (mA): 500 Corriente necesaria (mA): 100 Corriente operativa adicional (mA): 0 Xbox Kinect Audio, © 2011 Microsoft Corporation. All rights reserved.: ID del producto: 0x02ad ID del fabricante: 0x045e (Microsoft Corporation) Versión: 1.00 Número de serie: A44886D04130046A Velocidad: Hasta 480 Mb/s Fabricante: Microsoft ID de la ubicación: 0x14310000 / 9 Corriente disponible (mA): 500 Corriente operativa adicional (mA): 0 Thanks |
| Author: | Snapz [ Sat Feb 03, 2018 9:52 am ] |
| Post subject: | Re: Anyone using Kinect V2 on W10 on Imac Retina 5K end 2015 |
... Do you have the Kinect v2 SDK installed, checked the box when you installed the iPi Recorder? ... |
| Author: | Gerardo [ Sat Feb 03, 2018 2:49 pm ] |
Thanks Snapz, yes, I did that. I’ve uninstalled, reinstalled, rebooted with only the Kinect plugged in the USB ports... I suspect the USB 3.0 hub might not be compatible with Kinect that’s why I wanted to make sure that this specific iMac model works for someone before investigating more in depth. |
