It is currently Sun Nov 08, 2026 11:31 am
PostPosted: Fri Oct 04, 2024 9:07 am
I have four Brio cameras, each capable of 90 fps. Could you please advise on the optimal placement for them? and if I should do a full circle or a semi circle?, I also have tripods that can tilt the camera angles (up to down), is tilting recommended? Or should I keep the camera straight?
-Actor Height 1.7m
-Tripods can reach upto 2.7m
-Room size 17/13m.
https://PrivateLadyEscorts.com - Local Live Chat - No Verify - Anonymous Casual Dating - Live Private Lady Chat
PostPosted: Mon Oct 14, 2024 8:13 am
Your configuration looks promising. You can set two cameras on 1.2 - 1.7 meters height, and two others - as high as possible with your tripods. Full circle configuration should work better, but please avoid huge light objects like windows, lamps, etc in the view areas of each camera.
PostPosted: Fri Oct 18, 2024 6:12 pm
Works amazing,, I used ipi tracking + ai-based auto recover, there is some jitter, even after applying jitter reduction, i do have one request, refinement breaks the tracking, i presume it does not have ai-based auto recover, i hope you include that in the future updates
Users browsing this forum: No registered users and 147 guests
