ipisoft.com https://forum.ipisoft.com/ |
Brio Stream Best Placement? https://forum.ipisoft.com/viewtopic.php?f=7&t=10650 |
Author: | SiddTheKing [ Fri Oct 04, 2024 9:07 am ] |
Post subject: | Brio Stream Best Placement? |
I have four Brio cameras, each capable of 90 fps. Could you please advise on the optimal placement for them? and if I should do a full circle or a semi circle?, I also have tripods that can tilt the camera angles (up to down), is tilting recommended? Or should I keep the camera straight? -Actor Height 1.7m -Tripods can reach upto 2.7m -Room size 17/13m. |
Author: | andrew [ Mon Oct 14, 2024 8:13 am ] |
Post subject: | Re: Brio Stream Best Placement? |
Hello, Your configuration looks promising. You can set two cameras on 1.2 - 1.7 meters height, and two others - as high as possible with your tripods. Full circle configuration should work better, but please avoid huge light objects like windows, lamps, etc in the view areas of each camera. |
Author: | SiddTheKing [ Fri Oct 18, 2024 6:12 pm ] |
Works amazing,, I used ipi tracking + ai-based auto recover, there is some jitter, even after applying jitter reduction, i do have one request, refinement breaks the tracking, i presume it does not have ai-based auto recover, i hope you include that in the future updates |
Page 1 of 1 | All times are UTC - 8 hours [ DST ] |
Powered by phpBB® Forum Software © phpBB Group http://www.phpbb.com/ |
