| Problem with PS3 Eye setup, XP64 https://forum.ipisoft.com/viewtopic.php?f=7&t=4739 |
Page 1 of 1 |
| Author: | lordtangent [ Sun Oct 03, 2010 5:45 pm ] |
| Post subject: | Problem with PS3 Eye setup, XP64 |
The system I intended to use for capture is XP 64 bit. I'm unable to setup CL-Eye-Driver and iPRecorder doesn't seem to recognize the cameras either. Does any of the software work on XP 64 or do I need to use a different system? |
| Author: | apside [ Mon Oct 04, 2010 4:12 am ] |
| Post subject: | Re: Problem with PS3 Eye setup, XP64 |
It works on XP x64, we have tested it. |
| Author: | lordtangent [ Mon Oct 04, 2010 6:29 pm ] |
OK. Whatever it is about my system it's inhibiting my ability to install the driver or get iPRecorder to see the cameras. Does anyone have any debugging advice? |
| Author: | Earlack [ Wed Oct 06, 2010 12:02 am ] |
I don't remember exactly but the ipi installer should include the PSEye driver. Does it works when you launch the install ? Maybe XP64 needs a special driver. |
| Author: | Greenlaw [ Wed Oct 06, 2010 8:07 am ] |
That's correct. It seemed to me that when the drivers became included with the release version of iPi Recorder Installer I needed to make sure all the old beta software, including the CL-Eye drivers, were completely removed before I could successfully install the new software. In theory, you should not have to use the separate CL-Eye driver installer to use PS3 Eye cameras with the current iPi Recorder. FWIW, I know the current iPi Recorder installer works for Vista Ultimate and Windows 7 Professional, but I have not tested it with XP Professional. G. |
