ipisoft.com
https://forum.ipisoft.com/
RAW Bayer avi
https://forum.ipisoft.com/viewtopic.php?f=7&t=4821
Page 1 of 1
Author:  mrtnslzr [ Mon Dec 20, 2010 11:19 am ]
Post subject:  RAW Bayer avi
Hey there,
i started to work with ipi desktop and 4 ps3 eye cams and it works quite well so far.
but i have one problem: i want to use the recorded mocap videos (with ipirecorder) also in a video app. is there any possibility to convert the RAW video to a RGB video?
thanks,
Martin
Author:  Greenlaw [ Mon Dec 20, 2010 4:04 pm ]
Post subject:  Re: RAW Bayer avi
I haven't tried this but you might be able to output the video from DMC. Try hiding all the objects and setting the background to full opacity. You'll have to output each camera view separately. There is probably something about this I'm not thinking of but try it out and let me know how it works out. (Note: iPi DMC has a 2GB limit for animation output, so if the video is longer than this you will need to output it in multiple segments and assemble the video in a video editor.)
I haven't checked into this but it seems like there should be a player that can play back this format and output a more standard movie format. If anybody knows of one, please post the info here.
Edit: I meant 2GB of course, not 2MB. I've edited the above.
Author:  mrtnslzr [ Tue Dec 21, 2010 8:20 am ]
Thanks Greenlaw!
I'll try it out.... but since it's a pretty long video capture, i'll try to find a avisynth or After Effects solution.
if it works out, i will post it here!
best,
Martin
Author:  kILLJOY [ Thu Sep 01, 2011 4:54 am ]
Hey mrtnslzr,
did you find a solution for debayer in avisynth or After Effects? I'm also searching for a way to do that.
Best.
Author:  huahuashijie [ Thu Sep 01, 2011 6:02 am ]
I have a way ,there may have a good result but dont forgot the theory of ipi software
http://www.phpbb.com/
