| Multiple Kinect 2 hardware requirements? https://forum.ipisoft.com/viewtopic.php?f=7&t=9346 |
| Author: | EG_aqui [ Fri Apr 24, 2015 11:18 am ] |
| Post subject: | Multiple Kinect 2 hardware requirements? |
I have a couple of cheapish laptops that I want to use as slaves to do distributed recording using three Kinect 2 cams. The frame drops on the laptops are pretty extreme though (down to ~13) and I'm wondering what the best way to get that up to the necessary minimum is. Does anyone have experience using a multiple Kinect 2 system? |
| Author: | vmaslov [ Sat Apr 25, 2015 2:07 am ] |
| Post subject: | Re: Multiple Kinect 2 hardware requirements? |
Maybe your cheapish laptops do not satisfy Kinect 2 requirements. New Kinect SDK uses video card extensively. Also, there may be issues with some USB 3.0 controllers. Run Kinect Configuration Verifier tool on your laptops and see what it outputs. |
| Author: | EG_aqui [ Mon Apr 27, 2015 9:02 am ] |
I've got the fps working at a reasonable level now, but i'm having major issues with calibrating the Kinect v2.0s using a maglite. There are a ton of misdetects happening, is this more common with Kinect 2 than the original Kinect? EDIT: I spoke too soon. The Configuration Verifier is giving me a (!) for the USB Controller: "Supported USB 3.0 port detected with unknown bandwidth. Kinect may or may not be compatible with your hardware." The Verify Kinect Depth and Color Streams pane is also flickering a lot. It seems to be losing track of the kinect constantly. Is this a USB issue? If yes, what are the best fixes to try? |
| Author: | vmaslov [ Wed Apr 29, 2015 4:06 am ] |
If you get stable frame rate in iPi Recorder without much frame drops (10 per minute is an acceptable number) then I think you should not worry about the verifier. If not - try other USB 3.0 ports or get another laptop having Intel or NEC/Renesas USB 3.0 controller. Assuming the device is working OK, the problem with misdetects is generally caused by two reasons:
