It is currently Sun Nov 08, 2026 2:12 pm
PostPosted: Sat Jul 18, 2015 9:03 am
I have a question about my setup. I have yet to have located a space for this setup and I am advertising for a 48x48 foot area with no obstructions. Here is why:
My setup is 8 PS3 eyes on tripods, in a circle, one camera every 45 degrees.
If a person who is 5'10" stands in front of the camera with their hands raised over their head they would need to be 9 feet from the camera to capture them without clipping feet or hands.
I layout a 20 foot diameter circle. Then I layout 38 foot circle from the same center point. The reasoning being that the first 9 feet in front of each camera has the potential to clip off parts of the performer.
Is this a reasonable setup?
How much light is needed for this setup?
what if I added 8 more cameras at a different height along the circumference of the 38 foot circle for a total of 16 cameras? I have the Pro subscription.
What are the recommended heights for the cameras?
Leaving a 5 foot area outside the largest circle means we need a 48x48 space.
So far my experience has been great. I just have to clean up wobbly feet and arms and legs that wander.
Steve
PostPosted: Fri Jul 24, 2015 9:43 am
first, we do not recommend to get out of sight in any camera during tracking.
This often leads to tracking errors that require manual clean-up, which takes time.
So just use "inner" circle. In you case it can be up to 30 by 30 feet (48 - 9 - 9 = 30).
We ourselves tested setup with maximum distance from camera to actor around 30 feet.
With bigger distance (you have around 40 feet) there is a risk that actor image on video become too small for tracking. But you can give it a try.
For single-actor capture 8 cameras is quite enough. Circle setup you described is perfect, but we recommend to place 3-4 cameras at increased heights (8-10 feet).
Adding more cameras is always good, but this increase processing time. If you plan to track multiple actors, you'd better use 12-16 cameras. Circle setup with 1/3 of cameras at increased heights is the best option.
Lighting ideally should be ambient. Actor clothes colors should be clearly distinguishable, and look the same in all cameras.
