ASUS Xtion Pro not recognised by IPi Recorder
https://forum.ipisoft.com/viewtopic.php?f=7&t=9559
Author:  kempfpe [ Thu Apr 21, 2016 7:59 pm ]
Post subject:  ASUS Xtion Pro not recognised by IPi Recorder
Hi fellows,
I just encountered a strange problem with my two ASUS Xtion PRO (live).
1. Initially the sensors worked fine in IPi Recorder 3 .
2. Due to some reasons I have reinstalled (on Windows 10) the 32 bit sensor drivers: OpenNI 1.5.4.0 ; PrimeSense Sensor 5.1.2.1 ; PrimeSense NITE 1.5.2.21.
3. In the Device Manager I can see the devices correctly as "PrimeSense PS 1080".
4. But IPi Recorder 3 says that the package is not installed and does not show the sensors.
Does anyone encountered the same problem ? Have tried again and again deinstalling , cleansing and reinstalling, so I would desperately appreciate any help.
Thanks in advance
Peter
File comment: Windows says OpenNI and sensor drivers installed
File comment: Ipi Recorder says Xtion not installed
File comment: Device Manager shows Sensors
Author:  vmaslov [ Fri Apr 22, 2016 1:06 am ]
Post subject:  Re: ASUS Xtion Pro not recognised by IPi Recorder
I guess you've got 64-bit OS. Thus iPi Recorder runs as 64-bit application and cannot use 32-bit drivers.
Please install 64-bit OpenNI and drivers for Xtion.
http://files.ipisoft.com/3dparty/openni ... .0-dev.msi
http://files.ipisoft.com/3dparty/sensor ... redist.msi
Author:  kempfpe [ Fri Apr 22, 2016 2:27 am ]
thanks a lot for your reply.
Yes, I have W10 64 bit. So I tried to install the msi files you have attached (after thorough deinstallation and cleanup). The openNI Version 1.5.4.0 installes properly, but the sensor driver installation stops at the very beginning with the ominous message "please install OpenNI Version 1.2.0.4 or higher".
Any ideas ?
Best Wishes
Peter
Author:  vmaslov [ Fri Apr 22, 2016 4:08 am ]
Have you used the links I've posted in the previous message to download the installers?
I have just checked these installers on my Win 10, and they install properly in the specified order - OpenNI first, Sensor second. And iPi Recorder 3 detects that drivers for Xtion are installed.
Author:  kempfpe [ Fri Apr 22, 2016 2:11 pm ]
Yes i have used your links and installier it in the order you recommended.
OpenNi installs correctly, but the sensor driver comes with the error message mentioned in my last post.
Can it be that there are still some artifacts of a former installation and deinstallation of openni2 which might be interferring with the sensor driver installation? And how do I detect and get rid of those ?
Best Wishes
Peter
Author:  kempfpe [ Sun Apr 24, 2016 1:48 pm ]
I finally solved it: changed the execution sequence in the sensor installer in a way that it is not checking the launch conditions anymore. Thema it installed properly and everything works fine :)
Thanks a lot for your support
Peter
